P0884
Old May 25, 2009 | 06:04 PM
  #11
Erik913's Avatar
New Member
I plugged in the TCU and everything seems to be running just fine. My next task will be getting the carpet out and letting in dry in the sun. Thanks for all of your help and suggestions.
Old May 25, 2009 | 06:17 PM
  #12
4Driver4's Avatar
Tech Guru
Tech Guru
I hope you cleaned out the cowl drains and checked the water tray for correct position too.
No use treating the symptoms if you don't fix the problem.
Old Jun 5, 2011 | 03:35 PM
  #13
gsm1999's Avatar
Default TCM Audi 2006 Turbo 4B0 927 156 FE
I had the same problem.. My passenger side was fill with water.. I repaired and soldered all the spliced lines on the passenger side.. Repaired some DASH errors.. Like the driver door issue and epc...
Repaired all the cracks and leaks I had..
Still stuck with all the gears highlighted and limp mode.
- New tcm computer installed
- every spliced line fixed..
scanner diag codes;
Error Code: P0884 TCM Power Input Signal Intermittent
Error Code: P0798 Pressure Control Solenoid C Electrical
Old Jun 5, 2011 | 05:30 PM
  #14
OGBULLYLOCDAWG's Avatar
http://www.youtube.com/watch?v=STMCwA96VfI
Old Jun 6, 2011 | 05:46 PM
  #15
gsm1999's Avatar
Default tranny limp mode
I checked the following on the TCM;
Check one line TCM power supply circuit has POWER when ignition is Off - OK
Checked 2 black lines the has power when ignition is ON - I guess it's the TCM power supply circuit -OK
Checked the Brown wires (ground) TCM power ground - OK
Old Jun 6, 2011 | 05:50 PM
  #16
gsm1999's Avatar
Default Limp Mode reset procedure?
mrgearhead
A4 (B7 Platform) Discussion
Jan 30, 2017 06:44 PM
janserce79
24
Oct 2, 2010 09:59 PM
Sharm
Jan 27, 2009 05:22 AM
ExpStang
Jun 5, 2005 12:54 PM
Link20vt
Nov 16, 2004 09:15 AM
