PLEASE HELP...cannot remove strut from assembly
But if you have an impact wrench, just go to town on it, it will come off. You might want to hit it with some WD-40 too.
Here is one I found on the web...
<img src="http://www.russellsformen.com/images2/or-34769.jpg">
If you can't borrow, or make one, an air impact would make short work of it. That is what I use now.
Other option- buy new upper piece and don't worry about the old one.
You should now be able to see the top of the steel shaft. Put some grips on the shaft right up as near the top as you can. This will mark the shaft somewhat but as it will be at the very top it is beyond the range that the seals in the damper body actually ever reach so it does not matter.
When you re-assemble them, you may not need to do this at all. Very often you can get the nut to tighten up without locking the shaft at all, just see how it goes.
Whatever happens, do not ever risk damaging the shaft in the area of movement. It will cause the damper seals to fail if no time at all.
