is it possible to glue chip to steering column
I purchased a used a6 and only have one key. I bought a key online, had it cut, and the guy tried to program the rfid and said it's not a tp08, which is what the original had.
Is it possible to take out the little rfid chip and glue it to the steering column somehow so I can use any mechanical key. $350 a key from the dealer, for a car that's worth about 10K is just a little crazy. The key to USE the car costs 5% of the value of the car.
Was the guy doing the programming really familiar with these? I bought two keys new online, and made sure the RFID chip was the correct one for an 01 A6 C5. Once I had the proper Cluster PIN I easily programmed the car to them with my VAG-COM...
Jim
Even the dealer can't get it for you - they now connect the car right to the factory via the Internet to do the work, and the mechanic never sees the PIN, supposedly for security...
A good automotive locksmith can retrieve it with the right equipment - you might call around to see who in your area works on immobilizer keys. Once you have the PIN you can use the VAG-COM to program the car to the keys (they all have to be done at the same time, including the one you have now,)
Here's a good place to start:
http://wiki.ross-tech.com/wiki/index.php/Immobilizer
Jim
1) Gluing the chip to the steering column will most likely not work, at least not reliably. The effective area for RFID transmission is VERY small, and focused on the area where the key is supposed to be. The "antenna" on the car side is actually a ring around the key hole.
2) Just buy the "switchblade" section of the key. It will not cost $350. I just bought a new, programmed key from Penske Audi, which is one of the most expensive dealerships I've ever dealt with, and it cost a little over $200, programmed and ready to go. If you just want a spare key, you're set. If you want the remote section (back half) too, find one on eBay and program it yourself.
3) Unless you have a 45k mile perfect '04 A6 with a 4.2, your car isn't worth anything close to $10k. Sorry, we're all in the same boat.
