Radio for a 2000 Audi A6
Old Mar 4, 2013 | 03:27 PM
jeffkruse's Avatar
Default Radio for a 2000 Audi A6
I recently purchase an 2000 Audi A6 from a used car dealership, the radio did not work it needed a code. So after a week they final took the radio out to get the code. The radio works fine except for a little quirk. If you turn the radio off by pushing the button in while the car is running you cannot turn it back on until you pull the key out and put the key back in turn on and then turn off pull the key again then reinsert key then you can turn back on. The dealer said that is because the radio is a sympthony instead of bose like the speakers say. First of all has anyone every seen this and second I think he is pulling my leg because are they not the same thing
Old Mar 4, 2013 | 04:05 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Not an Audi dealer, huh? BOSE is the speaker system, which has nothing to do with the radio type, only the coding. For your issue, there is either a problem with the coding, the radio, or maybe the ignition switch.
Old Mar 4, 2013 | 04:15 PM
jcman's Avatar
What? Thats a buch of malarkey because all C5 Bose and non-Bose systems use the same Symphony I and Symphony II radio heads depending on the year.
Sounds like a wrong coding issue, hidden menu goof-up or even a plug/pin not making contact, does your display show BOSE when starts up/on?
Old Mar 4, 2013 | 04:30 PM
jeffkruse's Avatar
Actually it does show BOSE on start up. I thought it was bogus. And no it is not an audi dealership
Old Mar 4, 2013 | 04:49 PM
Airbag's Avatar
not to hijack as it is somewhat related, but i beard vagcom can make a non bose a bose ... is this true
Old Mar 4, 2013 | 04:51 PM
jcman's Avatar
If your speakers have the Bose badge then it is a Bose system with a Bose amp in the trunk like 4D4 said also its not a Bose radio its just configured to a Bose system.
Old Mar 4, 2013 | 04:53 PM
jcman's Avatar
No because you would need the Bose amp and speakers, its more than the BOSE display on the coding
Old Mar 5, 2013 | 01:55 AM
Airbag's Avatar
ah. thanks
Old Mar 22, 2013 | 08:12 AM
jeffkruse's Avatar
Default radio goes into search mode while driving
HAs anyone heard of this before. I am just driving down the street listen to a certain radio station and all of a sudden the radio goes into search mode. I turn the dail back to my radio station and it will stay there for a couple minutes and do teh same thing. Weird
ah. thanks
Old Mar 22, 2013 | 02:57 PM
jcman's Avatar
Check out this link for the DX/Local setting and others
http://www.ibiblio.org/tkan/audi/radios/symphony.html
