Old Jul 25, 2016, 03:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C5) Brake Guides
Print Wikipost
Reset rear caliper piston?
Old Aug 23, 2008 | 12:58 PM
rocketman4321's Avatar
Default Reset rear caliper piston?
First time for rear pads on the 2.7t. My usual giant C clamp won't push the calipers back in. I think I'm hitting the parking brake mechanism. What's the trick?
Haynes is silent on this, other than to use the special tool. What does that have that my trusty clamp doesn't?
Old Aug 23, 2008 | 01:14 PM
OOOOya's Avatar
Try screwing it in, righty-tighty
Old Aug 23, 2008 | 01:29 PM
computrtutr's Avatar
Default Benefit of the special tool....
The special tool has an end that will screw in the caliper piston, and also has a lip that puts pressure while screwing. It takes a HUGE amount of pressure with one of those awful cube extensions otherwise. Where are you?
Old Aug 23, 2008 | 01:33 PM
Default Another special tool you should use....
THE BENTLEY!!!
Haynes and Chiltons books are frequently incomplete and/or inaccurate. Considering what you are saving by doing the job yourself, pay the $20 or whatever and get a 3-day online subscription. It's really worth it.
Old Aug 23, 2008 | 01:35 PM
Sorry, said Haynes, meant Bently--I have the CD.
Old Aug 23, 2008 | 02:52 PM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
Default go to autozone or pepboyz and rent the tool
They take a deposit on your cc equal to the cost of the tool and then credit your cc when you return it.
Or buy one from Harbor Freight (CCS..cheap chinese s&*t) but be prepared to kluge the little pin that may shear if you turn too hard. I used a drill bit when the pin sheared but I had to keep sliding the drill bit every 180 degrees. The roll pin is CCS...I'll get a good US one one of these days...probably the next time I have to change rear pads. LOL.
Old Aug 23, 2008 | 03:19 PM
glostah's Avatar
Default It took me forever to figure that out when I did mine...
I thought I had frozen calipers at first!
Old Aug 23, 2008 | 05:57 PM
Default Now I don't feel so bad--must've ...
... lucked out on the first one--I think the piston rotated with the clamp. Didn't on the second. I found it by taking off the parking brake cable and pulling the lever, which extended the piston.
I've made a tool; if that doesn't work I'll try the parts place. I always thought those tools just pushed!
Old Aug 23, 2008 | 07:35 PM
01 2.7t's Avatar
Default don't forget to pull up and release the parking brake about 30 times
to set the calipers before you go driving
Old Aug 24, 2008 | 04:44 AM
A8CT's Avatar
it has to rotate inward while being pushed. Different than the front calipers so you need the tool.
