S6 conversion
<img src="http://www.corpimage.com/audi/42vsS6specs.jpg">
Camshafts with greater lift and modified timing ensure optimum cylinder filling, with the inlet valve timing matched to the engine's relevant operating point by a hydraulic camshaft actuator. At higher engine speeds an additional vacuum-controlled flap opens in the air cleaner housing and ensures that the engine can "breathe" more freely. The revised exhaust system with reduced back pressure creates a pleasant, sporting acoustic and has a high gas flow rate."
