Serpentine/Timing Belt Repalcement
I thinking of going for the $2100 but I through there were other parts that are wise to replace timing belt time such as the water pump, belt tensioner etc.
Any other suggestion on items to change at the same time the timing belt is changed?
Thanks,
However, I agree with Gary that all related parts should be done if you do the belt. Do not skip the cam adjuster seals, and seriously consider replacing the little plastic pipe by the oil cooler.
The serp belt replacement should just be for parts and maybe one hour extra labor for replacing serp belt tensioner and idlers.
What year car? 6-7 years and/or 90-105K for a TB is normal, serp belt should last 5-6 years as well.
As for the little cooling pipe...maybe replace but it's huge labor cost and you would just be replacing it with an OEM plastic bit at the dealer unless you forego the dealer/shop warranty and put in a bufkin aluminum pipe. If the car hasn't ever overheated chances are the coolant pipe will go 140K miles and 10 years. I agree it's a weak point but it's relatively reliable and the failure (cracks, leaks) generally gives a lot of warning..i.e., coolant on the floor underneath the passenger side at the front of the engine.
- timing belt
- water pump
- t-stat
- all rolling parts in contact with the belt (tensioner, idler..)
- serp belt.
The incremental labor for the serp belt is trivial. The 2nd tensioner is .. whatever it is.
You never do the serp belt job stand-alone, unless it breaks. It is not a critical failure (e.g.; when it breaks, nothing bad happens except your car stops running)
OTOH, if the TB breaks, your valves are toast. Many $k
The reason you do the H2O pump etc is that THEY are the cause of the TB failure. It doesn;t just break - its kevlar reinforced rubber.
G
- timing belt
- water pump
- t-stat
- serp belt.
G
Valve cover gaskets
Camshaft Valley Seals
Rear Camshaft End Cap Seals
anythingelse?
i ask, as i have been bitten by not changing everything, during my last timing belt change, and a definitive list would be very handy indeed.
Apologies if this is already in the forum
It's one thing to do scheduled maintenance on items such as TB and idlers and serp belts, water pumps, etc., but I have to disagree on Valve cover gaskets, Camshaft Valley Seals and Rear Camshaft End Cap Seals. If they're not leaking leave them alone!
