Smells like burnt rubber when I turn up the heat in my car.
Old Feb 12, 2008 | 03:54 AM
AudiMomma6's Avatar
New Member
Default Smells like burnt rubber when I turn up the heat in my car.
Any ideas? If I keep it low the smell goes away.
Old Feb 12, 2008 | 04:22 AM
squidix9's Avatar
No Bozos!
Default A number of things
I just ran into this too.
Check the cabin filter. I found mine completely blocked with a mouse nest. It kept air from flowing and the blower control module was overheating.Eventually took out the solar separation relay on mine. Also make sure your cowl vents aren't all packed with ice and snow.
Also could be oil dripping on the exhaust manifold. If you run synthetic, it smells slightly like burnt rubber.
Does it tend to go away while moving? If so, it may be that it is no longer sucking fumes form under the hood.
I also suspect my blower motor is on the way out. It's been too cold for me to get in and check it out. I want to pull the motor and if nothing else clean and lube it up.
Old Feb 12, 2008 | 05:40 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Which engine? Probably leaking oil from the cam chain tensioner seal.
Old Feb 12, 2008 | 03:52 PM
AudiMomma6's Avatar
New Member
Default Re: A number of things
It doesn't turn away when moving, but it goes away when I turn the heat down. No the heat, but the frequency which it blows at. Adjusting the tempurature has no affect. Thanks for all the tips!
Old Feb 12, 2008 | 06:47 PM
OneGuyInCA's Avatar
Default Ha... I smell that everyday. For me... it's gear lube dripping on my cat. Get used to it after
awhile.
john251
9
Nov 6, 2009 09:35 AM
lavezzaf - Anthony
Feb 28, 2008 06:21 PM
Avantadrive_Original
19
Sep 1, 2006 08:24 AM
DoubleA6
Jan 22, 2003 06:31 AM
