Squeeks
Old Jan 29, 2004 | 05:31 AM
bgnj's Avatar
New Member
Default Squeeks
Thanks to those who suggested checking the rear seat latches for the squeeking noises that were driving me crazy. All I had to do was put a small amount of WD40 on both the latch and post, and the noises have all but disappeared.
Old Jan 29, 2004 | 05:35 AM
frankie@work's Avatar
Member
You're welcome. I'm so proud of technical prowess 8-)
Old Jan 29, 2004 | 06:26 AM
HPH's Avatar
HPH
Default WD-40 works for a while...
...lithium grease (I have a spray can) lasts a little longer. I've come to view this as a maintenance issue rather than a true fix. You just gotta keep at it. HPH
Old Jan 29, 2004 | 06:33 AM
allroad'Ed now's Avatar
Senior Member
Yup. And spray white lithium will not run as easily as WD-40
Old Jan 29, 2004 | 07:09 AM
LMGotts's Avatar
Default Lower seat pivot points (where it folds down) can be troublesome too.
Heavy bicycle chain oil (mountain bike kind for wet environments) works well...
Remarkable how much more satisfying a squeak-free car is!
Old Jan 29, 2004 | 08:38 AM
JimR's Avatar
AudiWorld Uber User
25 Year Member
<*ding*> WD40 is only good for spraying down garden tools.
Old Jan 29, 2004 | 08:48 AM
Stoney's Avatar
Tech Guru
Which latch, exactly? (for posterity in the FAQ noises section)
Old Jan 29, 2004 | 09:25 AM
phred's Avatar
Senior Member
Default You know, since someone dissed WD-40
I read the labelling the other day, and it really doesn't say hardly anything about its lubricating qualities. Says something vague like "stops squeaks." Apparently because it's petro-based and is really a grease cutter and rust inhibitor.
You're right about the garden tools, that's what I was using it for at the time!
Here's an old-fashioned lube suggestion - beeswax. I'm trying it out on some squeaking on my GTI, apparently it's also used to lube wooden drawers and in ammo loading.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 29, 2004 | 09:45 AM
dougaross's Avatar
I always use Mr Moly Molybdenum Disulphide-oil, grease or spray
Old Jan 29, 2004 | 12:40 PM
Member
Say that 10 times fast.
stadtjunge
15
Apr 3, 2008 10:27 AM
applejacks
9
Jan 31, 2007 11:10 AM
psuaudi
Sep 18, 2005 10:37 AM
DirtMonkey_NWB6S4
14
Jan 21, 2004 02:07 PM
