Steering Angle Sensor
Old Sep 9, 2012 | 01:42 PM
jshaw5's Avatar
Default Steering Angle Sensor
I just replaced the passenger side outer tie rod end on my 2004 A6. The ball on the outer tie rod end had popped out of the socket when I was pulling into my driveway. I did not remove the entire tie rod assembly from the car, I just unscrewed the old outer tie rod from the assembly and screwed in the new one. I tried to match the number of threads, and I was planning to take it to the shop for an alignment tomorrow or Tuesday. I started the car up and drove down the block to see how it rode, and the ESP caution light came on. I ran the code and came up with the following code:
00778 - Steering Angle Sensor (G85) - 27-10 - Implausible Signal - Intermittant
I never had this code come on before the tie rod failed. Did I do something wrong?
Old Sep 9, 2012 | 05:05 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Get the car aligned before you drive it anywhere else. Reset the light after the alignment.
dripppps
Nov 14, 2013 04:06 PM
red90q
Jan 10, 2009 04:31 PM
bsewall
Nov 22, 2005 02:55 PM
Hokie - STI avant
Jun 10, 2003 11:06 AM
MarkG
Nov 7, 2002 08:17 PM
