Sun Visor part missing
http://www.ebay.com/itm/00-05-01-02-...be3fe7&vxp=mtr
Are they missing a piece?
It looks like there is some sort of collar, as shown below, that I am missing. Is it an orderable part?
http://www.ebay.com/itm/Passenger-Su...3881da&vxp=mtr
I don't think you can order just that part by itself, but why not call your Audi dealer to inquire?
Best bet - visit a local junk yard.
PS. I will check if it's a whole cylinder (meaning can't install it without sliding it onto the axis) or if it has a slit in it.
If you do the pen/bic barrel repair, remember to cover the barrel with a piece of tinfoil and protect the rest of the sunvisor from the heat gun.....the idea is to heat the barrel piece up hot enough to weld its slit shut and so you can mold the plastic through the tinfoil.
Just an fyi, I used cut the barrel of a cheap black pen with my hacksaw and then slit it. I then used a pair of needle nose pliers so split it enough to pop it on. all said, I was able to do both in 5 minutes and it is pretty decent, actually much better than without, and makes a satisfying click when it seats.
Not that most people have machining at their disposal, but this solution worked well for me. Certainly better than a used piece which would likely deteriorate, or paying the dealership for one (if they would sell just this part).
