TBB
Old Aug 13, 2002 | 09:23 AM
JohnA4Y2K2's Avatar
New Member
Default TBB
I've seen a lot of posts about torn TBB. Has this been fixed by Audi in newer cars? Have '02 2.7T. Should I be worried?
Old Aug 13, 2002 | 09:46 AM
Jack Orr's Avatar
Junior Member
Default Re: TBB
IMO, Audi fixed the problem mid year during '00 production. If it occurs at all any more, it is probably a chipped car or one belonging to a cowboy.
Old Aug 13, 2002 | 10:32 AM
GIACUser's Avatar
Junior Member
Default The problem was not fully addressed in my opinion ....
The clamps help but the part should have a reinforced neck much like a radiator hose. They all fail at the same point. I just bought 2 new TBBs and the design has not changed. The failure will certainly occur more frequently with added pressure and more frequent runs at high pressure. It happens on unchipped cars as well. I would expect that a sedate driver in a stock car would be able to get by for a long time without blowing it but if you run you car on the hard side frequency will go up. If you chip your car the frequency will go up again. I do drive it hard, I do run the Xchip but they blow all too easy, last one went for less than 500 miles. Worry about it... nothing to worry about, just replace it if it blows (15.00 or under warranty). If you want to prevent it you can get one from AWE that is Kevlar wrapped or get Bi-pipe. If you are stock and drive on the conservative side I wouldn't worry about it. It may or may not blow, if it does the car still runs, just no boost. You need to replace right away, so just keep a spare around.
Old Aug 13, 2002 | 10:41 AM
GIACUser's Avatar
Junior Member
Default Based on some pics that Midori pointed me to I am running the updated clamps...
which was supposed to be the fix.
Jason-mitchell
May 21, 2007 08:28 AM
lbarabas
Jun 22, 2004 11:38 AM
bl97
Apr 17, 2003 10:12 AM
track_junkie
Dec 24, 2002 10:15 PM
vrsix
40
Jan 24, 2002 07:59 AM
