Is there any procedure links for replacing shocks, simlar to the one just posted for CA's?
Old Jun 24, 2005 | 05:59 PM
R2.7TA6's Avatar
Member
Old Jun 25, 2005 | 06:06 AM
MCH 2.7t's Avatar
Member
Default This will help with the front... +my procedure for the rears
Rears are different from what is shown in the tech article, but not difficult. I've done fronts and rears multiple times. If you're interested we can talk at Mac this afternoon.
Quick procedures for rear:
1. Remove the 2 8mm(?) nuts that hold the parking brake cable to the lower control arm
2. Remove the brake caliper from the caliper carrier.
3. Remove the outer pivot bolt on the LOWER control arm. IMPORTANT NOTES about this method:
- the outer bolt on the lower control arm is used for alignment purposes. Before removing the bolt - place a mark on the bolt-side washer and place a corresponding mark on the control arm. Clean the surfaces first and use a permanent marker. Do not make your mark on the nut-side washer - this washer has to much play and will not be accurate. When you re-install the bolt, line up the marks and your alignment will be maintained. I've done this multiple times and the alignment, as measured at a good alignment shop, is always spot-on.
4. Remove the lower shock nut and bolt
5. Remove the 2 bolts that attach the upper spring perch to the body.
Steps 1 & 2 allow you to push the lower control arm down. This, in turn, allows the shock-spring combo the slide down and out.
6. Using spring compressors, disassemble the spring/shock combo.
7. Re-assembly is the reverse of these steps. Use a new lower shock nut and bolt and 2 new upper spring perch to body bolts.
Mike<ul><li><a href="https://www.audiworld.com/tech/wheel28.shtml">https://www.audiworld.com/tech/wheel28.shtml</a</li></ul>
Old Jun 25, 2005 | 09:32 PM
MikekiM@PureMS's Avatar
Former Vendor
Default One note..
For the rears...
After you remove the outer lower alignment bolt, that lower control arm has a little spring to it, since it still is bolted to the lower subframe.
This can make getting the shock out a little challenging. Don't be afraid to push down hard on that lower control arm, you won't hurt anything. Just be careful since it does tend to spring back.
Old Jun 26, 2005 | 06:04 AM
MCH 2.7t's Avatar
Member
Default On day I'm going to take a picture of my shoe on the control arm...
holding it down as I us both hands to manuever the shock/spring out.
swolh
Audi allroad
Apr 7, 2012 06:50 AM
dorsal900
Nov 24, 2008 06:46 PM
Brandono
Audi 100 / A6 (C4 Platform)
9
Dec 1, 2006 02:42 PM
Shard7
Jun 24, 2006 11:11 AM
JDG
Oct 2, 2005 12:01 PM
