Is there a automatic transmission fluid level sensor?
When cold it shifts hard and when coming to a stop and down shifting into 1st it seems to hold onto 2nd and then clunk into 1st dropping the RPM's noticeably. It actually stalled on me twice today in traffic while coming to a stop. 2002 A6 Avant 3.0. When warm it generally works better.
The "auto rebuild specialist" I talked to said that the computer would tell me if the fluid was low. VAG-COM shows no codes but something definitely is not right here. I've read here too that when changing or filling the trans fluid you actually have to put it in gear and watch the temperatures to make sure that the fluid level gets topped off at the right level. I have no idea what method they actually used when putting it back together, and of course the problem goes away when they drive it.
Any ideas?
They also supposedly replaced some sensor on the transmission that lets the ECU know what gear the car is in or what speed the output is spinning. That seemed to help for a few days but the symptoms are now to a point where the wife won't drive the car anymore.
A torque converter issue generally throws a code. Have someone who knows what they are doing and has the correct diagnostic software look at it.
I hope you haven't been driving it too long.
You have to go through a specified routine to get the fluid warm but not too hot.
If VAG-COM could read the info, all this would not be so involved.
It is also obviously very dependent on temperature.
Grant
To check, elevate the car keeping it level. Loosen the fill plug but do not remove it. Start the car from dead cold. Set VAG-COM up to monitor fluid temp. Fill trans until fluid runs out. Let car come up to temp while fluid trickles out the fill hole. When temp is in spec, install and tighten the plug.
