used convinience control module recode...
1. remote is not working on the key fob. (put new batteries in )
2. even manual lock is not working properly.
if i want to unlock the car,instead i have to lock the car for about 20times, until the locking clicking sound is gone, then i unlock it manualy, all four doors will unlock.
when i did unlock the car, lets say im left something in the car, i unlock as i said in section 2, i have to wait about 1 minute, so i can lock the car again. i took it to a independent garage, the electrician is certain, the new module is the pain in d ***, it need to be recoded.
any idea??? i just purchased the vag-com, still waiting for it to ship to me. so any help would be great
Also, did you by chance check that there was a code from you old convenience module? Plug the old one back in and scan with vag-com. Then select the recode button and write down those two codes.
Then plug in your new module and scan with vag-com. Click on the recode button and copy the codes you just wrote down.
I would try simply recoding the keys to the car first. That may be enough.
Do a search on this forum on how to code your key fob for the instructions.
