VIDEO: replacing the center LCD screen in the cluster
Old Apr 28, 2012 | 09:38 AM
  #11
k0mpresd's Avatar
Originally Posted by audifirst
I invested in my business, my product I use is my own product that I manufacture, but again you are getting away from post, I would be embarrassed to post your installation procedure ...
really? you manufacture your own lcd panels? thats what youre saying? would love to see that as well.
Old Apr 28, 2012 | 09:39 AM
  #12
audifirst's Avatar
Originally Posted by k0mpresd
i work on bga stuff all day. never a problem. i work out of a room in my home. i do what i do to pay my bills. you can hate all you want. i dont care. what i do works and i have lots of satisfied customers. im not using a screwdriver either. it is only to pull up the ribbon after the hot air melts the solder enough to loosen it. i also fix abs modules, maybe you should have contacted me.
i do me7 emission deletes and immo2/3 deletes.
if you work on electronics I would invest in some better equipment.. because I wouldn't want to send cluster to you after seeing this video.. I would expect this from Noob not from someone like you said work all day on bga stuff.
Old Apr 28, 2012 | 09:44 AM
  #13
audifirst's Avatar
Yes I do.. for the last 5 years I have been making them, I stopped using Chinese LCD because of quality issues, Ask "mpower" I sent him my product to him for test..
Old Apr 28, 2012 | 09:45 AM
  #14
k0mpresd's Avatar
lets see one.
Old Apr 28, 2012 | 09:46 AM
  #15
ezveedub's Avatar
Seriously, who cares about you're comments on the OP's repair work procedure?? If he does it this way and it works fine, so be it. I've seen plenty of electronics worked on all day on a table without grounding and it won't short out anything. It's all about the work environment conditions and some have no static electricity around. In a humid climate, you could roll the electronics on a carpet and not get any static what so ever. Seems like your badgering the OP for your own benefit. What business are you running that you're trying to promote?!?!?!
Old Apr 28, 2012 | 09:48 AM
  #16
audifirst's Avatar
lets see one.
OK I will take photo of my product vs the one you get..
Old Apr 28, 2012 | 09:55 AM
  #17
k0mpresd's Avatar
he says you did invest in a bonding machine. but he hasnt installed one of your panels yet. i order oem panels from him if someone requests oem over the aftermarket panels.
  #18
audifirst's Avatar
Promoting, I don't promote my business. do you see me advertising here on this side showing photos of my business and me doing repair ? I am just concern about the quality of work that is showed here..is poor..
Old Apr 28, 2012 | 10:14 AM
  #19
jcman's Avatar
Default Just like being in a school yard
Lets not get too rash here; its a good informative post by the OP that I've seen before and felt the vid could use a little instructive verbal audio.
I noticed the same post on QW and the members there were not as snarky as here?
The part he is showing is the big question part of the whole process and I can say that's a plus to share.
So for what its worth, Thanks man!
AKA John V.
Old Apr 28, 2012 | 11:46 AM
  #20
Just Me's Avatar
Tech Guru
Tech Guru
So i'll ask again, as a guy with two MIT engineering degrees, but no experience with SMDs, can you elaborate please? Maybe i'll learn something. All i hear now is "this sux".
