weird issues
also, the driver side AC is crap but the passenger side AC is AWESOME, do i have a broken evap unit? :/
Try helping the side that's struggling to with your hands. Or when the window slows down, stop it with the flick of the switch, roll it down briefly (no more than half an inch), then roll up again. May have to do this a few times in order to close it.
Basically, when one clip breaks, that side is dragging and creates resistance for the motor. Hence it slows down. When the resistance gets too high, the window will roll down. Pinch protection.
as far as the AC leak, why would an AC leak result in the driver side to be room temp and the passenger side to be cold, wouldnt both be cold.
Have it charged and checked for leaks. If no leaks are found, expect to change the evaporator in a year or two.
One other possibility is a flapper vacuum motor is toast and is stopping the driver side from getting AC air.
Our 2K4.2A6 went through several iterations of suck/recharge good for a year each until I just started recharging it every spring. After a couple years it now holds charge for about two years....still cold.
