Window One-Touch Operation is Gone!! EEks!
Old Jul 5, 2011 | 06:48 AM
98Quattro's Avatar
Default Window One-Touch Operation is Gone!! EEks!
Ok, so recently my alternator went out on me. After replacing my intial bad battery before doing the alternator swap I noticed that the windows would not roll down using the one-touch method. I had to hold down the button.
On Friday, my bad alternator was swapped out for a remanaufactured one. However, I still have the same issue with the windows.
Is there some sort of procedure I don't know about to get the one-touch operation working again?
thanks in advance!
Old Jul 5, 2011 | 08:08 AM
jseklund's Avatar
This is normal. Close all the windows completely. Then, hold each button down until the window goes all the way down and hold it for 5-10 seconds. Then pull up on each button until it reaches the top and hold it for 5-10 seconds. You can do them individually or 2 at a time, whatever. You just need to "retrain" the window. Takes about 1 minute.
Old Jul 5, 2011 | 09:43 AM
98Quattro's Avatar
Will it work if one of my windows doesn't go up or down?
Old Jul 5, 2011 | 09:48 AM
jseklund's Avatar
I believe each window is independant of the others...so you can program the 3 that work and the 4th (obviously) you can't raise or lower, so....it just won't move.
You do not have to do all windows at once...you can do one at a time.
Old Jul 5, 2011 | 09:57 AM
98Quattro's Avatar
Cool, thanks! I'll try that when I get home.
norwestie
Q7 MK 1 Discussion
Dec 31, 2015 07:37 AM
kables
Q7 MK 1 Discussion
Oct 16, 2015 04:11 PM
arbrx
RS4 (B7 Platform) Discussion
Jun 16, 2008 08:33 PM
TraderVic
Aug 20, 2002 03:25 AM
UCLA Matthew
9
Jul 2, 2002 12:31 PM
