A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
'06 with Alignment problems.
Old Jan 2, 2009 | 10:46 AM
cosmobeauregard's Avatar
Default '06 with Alignment problems.
Oh wise sages of Audi World, I summon your collective wisdom to free me from Dealer run around. I've got an '06 A6 4.2 Quattro with Electronic Suspension and 18" wheels. The car goes like stink and handles better than it ought to, however there is a slight pull to the right at all speeds. Audi dealer has set the alignment once and found it to be within specs 3 additional times. Local alignment shop has set the alignment once but just as before after 3 months or so the pull has returned. Local alignment shop now claims the alignment is within specs and he suspects the front sub frame has shifted. I've had great service from this shop for the past 20 years and I want to believe him. Anyone else had a similar experience with alignment issues?
Old Jan 2, 2009 | 11:25 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Have you tried moving tires around?
Old Jan 2, 2009 | 11:43 AM
thrilla from manila's Avatar
Default or just check tire pressure
I dunno sometimes it gets over looked
Old Jan 2, 2009 | 06:29 PM
Default Re: Have you tried moving tires around?
Affirmative on rotation and pressure checks. Believe me as prone to tire wear as these puppies are, I stay on top of them. Running Yokohama W4S currently, the same issue exsisted with the Continental's that came equiped with the car when new. The problem seems to be Camber related specifically. Thanks for the reply(s)
Old Jan 2, 2009 | 06:36 PM
Default Re: or just check tire pressure
Running Nitrogen and they're dead on the money. Great thought though. Thanks for the reply
thehedge
Dec 30, 2010 07:18 AM
wisconsin_quat
12
Feb 27, 2009 04:14 AM
Nate (ETKA+Scumbag)
Jan 4, 2007 11:09 AM
CGboy
Dec 2, 2004 08:03 AM
dougs2.7T
Feb 26, 2004 06:53 PM
