2005 A6, iPhone/iPod?
OK, we have this nice MMI, with CD changer, no NAV (on mine). Bluetooth built in, seems to work OK for calls, but I have a very early MMI version (will be updated pretty soon). It would seem that if Bluetooth is built in, that A2DP should be possible. But it appears that even with an update to the MMI firmware, there's something called 'AMI' (Audi Music Interface?), which needs to be added, and then you could add a separate A2DP Bluetooth thing?
Seems like it should be easier and less expensive(?)
What are others doing to integrate iPod/iPhone with their 'older' C6?
-Darryl
But you will probably need to update the MMI software to at least 4140 for it to work properly. You can get the disks inexpensively and make sure you read https://www.audiworld.com/forums/sho....php?t=2607361
-Darryl
If you do swap the CD for the AMI you will need to make sure you are updated to 3360 or later and that needs to be done BEFORE you remove the CD change since it is needed for the upgrade. Also, make sure you keep the changer in the event you need to service the MMI and load new software.
If there are any questions, I'm happy to answer what I can.
Here are some pics of the interface.
-Darryl
How they look when ordered from Audi.
Thanks,
Pat
