A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
3.2 Head gasket replacement Help
Old 03-24-2019, 07:09 PM
Dj'Freeze Gmb's Avatar
Default 3.2 Head gasket replacement Help
Hello so I've been looking all over to find out the correct way to replace the head gaskets on my 3.2. looking under the hood I have oil in the screws of my valve covers was thinking if I have to replace the valve cover gasket I wanted to do the heads too but I can't find a video anywhere on getting to the head of a 3.2
Old 03-25-2019, 01:26 PM
Default So no one knows
Old 03-25-2019, 01:53 PM
raj99's Avatar
Originally Posted by Dj'Freeze Gmb
There's a few folks here who certainly know...but it's not as easy as you might want it to be. On the scale of easy a valve cover gasket job is a 2, whereby doing the head gasket is a true PITA and I wouldn't even consider doing it with the engine in the car. That said, once the engine is out there'd be a LOT more things you can proactively do to maintain.
It sounds like you got a 3.2 C6 on the cheap and I'd first determine exactly where and how much it's leaking from. Wash teh undercarriage, drive it and get it up on a lift and inspect and determine all such leaks, then start throwing money and parts at a problem. Also, how eactly do you know that you've got a blown headgasket?
Lastly, invest some money in a good manual for such a job (i.e. erwin).
Old 03-25-2019, 02:48 PM
Default Looking bad
The car overheats
Coolant cloudy white
Oil milky Brown
Little to no white smoke out of tail pipe
After reading and watching videos on here I popped the hood and looked
Valve covers look to be replaced before and Audi definitely didn't do it
Plus the guy that gave it to me said he was driving it with a broken coolant pipe so
My first instinct is head gasket
KYNZ
09-04-2007 08:28 AM
audispiff
08-06-2007 08:32 AM
Q4TRO
Audi 100 / A6 (C4 Platform)
07-12-2007 07:42 PM
randerson
Audi Original "S" Cars
10
01-13-2005 03:19 PM
AwdiA4
09-05-2003 11:20 AM
Quick Reply: 3.2 Head gasket replacement Help
