A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
wnat to try VCDS lite with audi s6 2007 what cable to use??
Old 07-20-2014, 03:02 AM
rikardo82's Avatar
Default wnat to try VCDS lite with audi s6 2007 what cable to use??
I want to try VCDS lite but have problem connecting it, error: port status OK interface not found, in device manager I set it to com1 and in vcds also test com1 port in device manager no yellow signs so drivers installed. I use ELM 327 OBD cable. I can connect with other software no problem - proscan. What cable I should buy so it work with S6 2007???
Old 07-20-2014, 08:26 AM
mill3241's Avatar
I have tried a few different cables and the only one I've been able to get to work is a genuine Ross-Tech cable.
Old 07-20-2014, 09:35 AM
uberwgn's Avatar
Old 07-22-2014, 08:18 AM
rikardo82's Avatar
Originally Posted by uberwgn
and where to buy that cable and how much it cost?
Old 07-22-2014, 08:29 AM
stroker351w's Avatar
I have an '08 S6.
You need either this:
Ross-Tech Store: VCDS License with HEX-USB+CAN Unlimted VIN (All VAG)
or
Ross-Tech Store: VCDS License with HEX-NET (WiFi/USB) 10 VINs (All VAG)
I have the second one. It's a decent upfront investment.
Old 08-08-2014, 03:14 PM
linkeds2's Avatar
Two things i want to update you guys,
First: Found out that VCDS Lite finds the cable and setting the COM port to either 1-4 in the advanced setting the device manager works.
To resolve the VCDS Lite saying Interface: not found, connect the cable to the vehicle THEN run the test on the correct COM port.
Second:
This is all pointless because VCDS Lite does not communicate with CAN modules (outlined on the description for VCDS Lite on the Ross-Tech site). C6 A6/S6s are CAN so you'd connect to the vehicle but you will receive a "no response from controller" when attempting to enter a module.
ONLY VCDS can be used on our vehicles which requires the genuine cable or registered program to work.
Took me a while of internet searching to come to this realization.
Drewseff (05-06-2020)
Old 08-09-2014, 03:43 AM
SchwarzS6's Avatar
Did you even read the previous posts? As mentioned above you need to purchase the Ross Tech cable linked above. The Lite cables will either not work or will only allow to read the standard OBD II codes.
Old 08-09-2014, 03:54 AM
urs6_ma's Avatar
Default Support Ross-Tech!
Cripes, you spent $20k or $60k or whatever on your Audi, and there's one vendor who makes a great software application to manage/modify your vehicle. This vendor has been supporting the Audi community for many years.
Spend the $300 on a genuine Ross-Tech cable. Support the vendor that made it possible. If you don't, that application won't be around for you to use.
Old 08-09-2014, 11:37 AM
SchwarzS6's Avatar
^+1 What he said
09A4
03-21-2018 06:20 PM
markN1689
Audi A3 / S3 / RS 3 MKII
03-19-2016 02:16 PM
GoTT83
11-19-2004 02:51 PM
abcdefghijklmnop
05-22-2003 07:19 AM
s4rocket
11-10-2001 11:13 AM
Quick Reply: wnat to try VCDS lite with audi s6 2007 what cable to use??
