A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Disconnect the Battery Question.
Old Nov 10, 2010 | 09:28 AM
RichiePuente's Avatar
Default Disconnect the Battery Question.
Can anyone help please?
I’m not sure if I should disconnecting the battery, I wanted to ask before doing this as I don’t want to be screwed.
Will the car will turn on again, or is this something the dealer will need to do, so they can reset something???
2005 Audi A6
V8 4.2
(80,000 miles)
Old Nov 10, 2010 | 09:38 AM
pcamaj's Avatar
2005 Audi A6
V8 4.2
(80,000 miles)
mine died once all of the sudden and nothing really happened.. i did give it a jump. i did not remove it entirely though...
Old Nov 10, 2010 | 11:43 AM
pavils's Avatar
Car will start up just fine, it's pinch protection and a few other settings that will be lost if battery is disconnected for extended period of time. Dealers will charge 0.5-1.0 shop hours for this, an independent will likely do it for less.
Recommendation from others is to have a battery booster connected to the leads while swapping out, while some just say to do the swap quickly. And still others say "who cares about those silly settings"
Old Nov 10, 2010 | 12:10 PM
chuckee98's Avatar
When I disconnected the battery for a steering wheel swap, I had to resynchronize all the keys by inserting them into the ignition switch and starting the car for each key, and run all the windows through auto down and up to reset them. This was what the Bentley manual had instructed me to do.
Old Nov 12, 2010 | 06:04 AM
mystrodo's Avatar
As Chuckee98 mentioned, you can lose important settings so connect a jumper batt to your jumper lugs under the bonnet/hood when you disconnect the main batt in the trunk.
SSA6
A6 (C7 Platform) Discussion
48
Jul 7, 2024 06:41 AM
fnarq
A4 (B9 Platform) Discussion
9
Jan 13, 2017 10:52 AM
johnd64
19
Feb 22, 2016 10:26 PM
red90q
Oct 25, 2006 05:59 PM
definitiveprep
Apr 15, 2005 09:53 AM
