Error Codes, help with some?
06449 - coolant fan control module malfunction, (as far as I know the fans have been working fine, this isn't related to the AC though is it?)
05495 - right electro hydraulic engine mount solven.val.,open
00658 - operating unit
00797 - Sunlight Photo Sensor
01844 - Fresh Air blower control Module (this seems related to another error from google, Climatronic Control Module malfunctioning, look below)
00532 - supply voltage (i am using an aftermarket battery, guessing this may be causing some of the errors?)
02072 - invalid data received from battery energy CM -A-
01320 - Climatronic Control Module (Now this sounds related to A/C from what I am reading, some people say you can calibrate this and the sensors within the Audi MMI?)
02103 - veh. elec. sys. ctrl. mod. 2 (not sure, haven't found anything about this on google)
02277 - static current state
02272 - static current state
02274 - static current state
02256 - static current
00166 - access/start authorization switch
01176 - key 1
