A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Key doesn't fit in door lock.
Old Aug 29, 2012 | 05:44 AM
cebo0650's Avatar
Default Key doesn't fit in door lock.
I have Advance Key so I never use the door locks but yesterday I noticed my key doesn't fit in the door lock. It simply won't even go in. It fits in the ignition just fine and of course starts the car as well.
Is the key hole on the driver door for the valet key only? What's going on here?
Old Aug 29, 2012 | 06:17 AM
MainlandMig's Avatar
i doubt that.
is something jammed in the door?
r u the 1st owner?
maybe previous owner swapped out door lock or door or ignition?
Old Aug 29, 2012 | 06:47 AM
cebo0650's Avatar
I'm not he first owner, but have had the car for almost 3 years now. It was a CPO car so if the lock was changed I doubt Audi would certify as CPO with ignition and door locks that don't match.
Doesn't look like anything is jammed in there, but maybe because I never use it is just rusted shut. The key goes in about half way, but no further.
Old Aug 29, 2012 | 12:53 PM
AsianiceStyle's Avatar
I had the exact same issue when I bought the car. I put a little wd-40 on the key and wiggled it in till it can turn. I do this every once in a while so when I actually do need to use my door lock I can use it.
Old Aug 29, 2012 | 07:05 PM
cebo0650's Avatar
Well I feel like a total tool now
Tried again earlier today and used a bit more force. The key went in and sure enough it works as expected. I put some lubricant in the lock and all is good now.
I'll make sure to lube it once in a while. Thanks for the tip AsianiceStyle.
Old Aug 30, 2012 | 04:01 AM
KevinGary's Avatar
Community Builder
Virgins require a lot of work
Old Aug 30, 2012 | 08:48 AM
ericA6's Avatar
LOL! I love that comment!
Old Jan 28, 2018 | 12:26 PM
Witchhunt's Avatar
Banned
Default Mone
Mine also? I have 2 sets and neither of them will go in to the doors
Old Dec 23, 2020 | 09:16 AM
Adam Stefanyk's Avatar
Default Spare Plastic Key Broke Off
I tried all the graphite/WD-40 lubricating tricks with no luck. Took the door lock cylinder to a locksmith, they pulled out the cylinder, and found that part of a black spare key had broken off inside the lock cylinder. They were able to get it out and now it's working fine
Old Dec 23, 2020 | 11:36 PM
kelisko's Avatar
Banned
Guys, do this at least once a year.
