A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
New Battery
Old Jan 22, 2012 | 12:22 PM
royclark's Avatar
Default New Battery
Is this the procedure for A6 c6 (4F) battery replacement?
<TABLE class=gumax-row width="100%"><TBODY><TR><TD class=gumax-row-right vAlign=top><!-- article-picture --><!-- Get page name --><!-- end of article-picture --><!-- content-body --><!-- content -->Audi A8 (4E) Battery Replacement
(Redirected from Audi A6 (4F) Battery Replacement)
From Ross-Tech Wiki
Jump to: navigation, search
<!-- start content -->This procedure details how to replace a battery in a vehicle using a separate battery management control module. See the separate instructions for models where the battery management control module is a slave/subsystem of the gateway.
The following procedure does assume you are using a battery supplied by VW/Audi, all necessary details for the following steps can found on the battery itself. Make sure to refer to the factory repair manual in order to fulfill all additional prerequisites.
[Select]
DRIVETRAIN
[61 - Battery Regulation]
[Coding - 07]
Use the pull down menu to select the battery (slave) listed as #1.
[Battery Coding]
  • Enter the new Battery Part Number (10 or 11 digits).
  • Enter the new Battery Serial Number (10 digits).
  • Select the new Battery Vendor.
[OK]
[Do it!]
[Close Controller, Go Back - 06]
Your new Battery should now be coded and the Battery Control Module should be aware of the new Battery.
Note: The 10 digit serial number may be preceded by the battery vendor code, for instance VA0 of Varta. If the code is VA0310314E04G then drop the VA0 and just enter 310314E04G. Sometimes the battery part number sticker can cover up the white sticker with the serial number.
</TD></TR></TBODY></TABLE><TABLE class=gumax-row width="100%"><TBODY><TR><TD class=gumax-row-right vAlign=top><!-- article-picture --><!-- Get page name --><!-- end of article-picture --><!-- content-body --><!-- content -->
bballfreak
9
Apr 14, 2019 06:59 PM
gorkyc
Oct 4, 2015 07:00 PM
flynavy
Q7 MK 1 Discussion
Sep 30, 2015 05:19 PM
navy_anav
Sep 30, 2015 01:38 PM
ebod0000
A6 (C7 Platform) Discussion
Sep 30, 2015 10:27 AM
