A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
no start- vcds doesnt recognise engine control module.
Old 02-20-2018, 01:40 PM
wagonpitt's Avatar
Default no start- vcds doesnt recognise engine control module.
For last few weeks/month car has been actong up. When driving it will basically turn off and on while im driving, makes a big jerk and loses power then comes back to normal. This happens any speed or gear .
Also sometimes when i slow to near stop or make full stop it will shut off and back on by itself wothout me turning key at all .
also sometimes when i get it in and turn key nothing happens. I either hold key in on position until it notices and turns on. or i remove key then put back and try to start. It usually starts on second or third try.
Tried to start one week ago. I turn key. All lights and fans and evwrything comes on but when i turn to on position nothing at all happens. No clicks no turn over nothing . Tried a few times holding key in on position then removing and retrying but nothing worked. At first i thout maby starter. When i tried to scan vcds could not connect or recognise most modules. I tried disconecting battery over night and still same issue. This went on for a week. Today i decided to give it a try and started first try. Ive been running it for last couple hours. Shut it off and restarted a few times no problems. I im guessing its relatsd to ignition switch fault, part\neutral switch fault or maby another relay or fuse.
Tuesday,20,February,2018,16:36:48:11863
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
Ross-Tech: Home
VIN: WAUKH74F67N044328 License Plate:
Mileage: 249070km-154764mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53
55 56 61 62 67 72 77
VIN: WAUKH74F67N044328 Mileage: 249070km-154764miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 C HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0070
Revision: --H19--- Serial number:
Coding: 010D0109190F0120
Shop #: WSC 90378 999 100058
VCID: 2C5770768F25602494-8078
10 Faults Found:
009217 - EVAP Leak Detection Pump Control Circuit
P2401 - 007 - Short to GND - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 4
Fault Frequency: 254
Reset counter: 40
Mileage: 246011 km
Time Indication: 0
Date: 2018.01.23
Time: 13:14:52
Freeze Frame:
RPM: 192 /min
Mass Air / Rev.: 605.0 mg/str
Temperature: 42.0°C
Start
Voltage: 10.10 V
Speed: 0.0 km/h
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 150
Reset counter: 38
Mileage: 246011 km
Time Indication: 0
Date: 2018.01.23
Time: 13:14:53
Freeze Frame:
RPM: 608 /min
Mass Air / Rev.: 218.0 mg/str
Temperature: 84.0°C
Idle
Load: 26.3 %
Speed: 0.0 km/h
008309 - Position Sensor for Intake Manifold Tuning Valve (G513)
P2075 - 008 - Elect. Malfunction - Intermittent
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Reset counter: 40
Mileage: 246011 km
Time Indication: 0
Date: 2018.01.23
Time: 13:14:54
Freeze Frame:
RPM: 768 /min
Mass Air / Rev.: 196.2 mg/str
Temperature: 42.0°C
Idle
Voltage: 12.44 V
Speed: 0.0 km/h
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 007 - Open Circuit
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Reset counter: 40
Mileage: 246011 km
Time Indication: 0
Date: 2018.01.23
Time: 13:15:59
Freeze Frame:
RPM: 1344 /min
Mass Air / Rev.: 201.7 mg/str
Temperature: 24.0°C
Idle
Load: 27.5 %
Speed: 21.0 km/h
000769 - Cylinder 1
P0301 - 009 - Misfire Detected
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 2
Reset counter: 38
Mileage: 248701 km
Time Indication: 0
Date: 2018.02.12
Time: 21:17:54
Freeze Frame:
RPM: 1088 /min
Mass Air / Rev.: 114.5 mg/str
Temperature: 76.5°C
Part Throttle
Time: 25.6 s
Speed: 0.0 km/h
002129 - Park/Neutral Switch Input Circuit
P0851 - 007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 76
Reset counter: 40
Mileage: 248989 km
Time Indication: 0
Date: 2018.02.13
Time: 21:14:40
Freeze Frame:
RPM: 1216 /min
Mass Air / Rev.: 169.0 mg/str
Temperature: 85.5°C
Part Throttle
Load: 30.2 %
Speed: 59.0 km/h
009525 - Ignition Switch; Run/Start Position Circuit
P2535 - 006 - Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 40
Mileage: 249065 km
Time Indication: 0
Date: 2018.02.14
Time: 10:05:25
Freeze Frame:
RPM: 832 /min
Mass Air / Rev.: 81.8 mg/str
Temperature: 84.0°C
Idle
Voltage: 11.83 V
Speed: 0.0 km/h
008504 - Accelerator Position Sensors (G79) / (G185)
P2138 - 006 - Implausible Correlation - Intermittent
Freeze Frame:
Fault Status: 11101000
Fault Priority: 4
Fault Frequency: 2
Reset counter: 40
Mileage: 249070 km
Time Indication: 0
Date: 2006.03.18
Time: 01:03:26
Freeze Frame:
RPM: 160 /min
Mass Air / Rev.: 610.4 mg/str
Temperature: 42.0°C
Load: 14.9 %
Load: 11.4 %
Bin. Bits: 00000001
008487 - Accelerator Position Sensor 2 (G185)
P2127 - 008 - Signal too Low - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 4
Fault Frequency: 2
Reset counter: 40
Mileage: 249070 km
Time Indication: 0
Date: 2006.03.18
Time: 01:03:44
Freeze Frame:
RPM: 832 /min
Temperature: 40.5°C
Idle
Load: 3.1 %
Bin. Bits: 00000001
004688 - Fuel Level too Low
P1250 - 000 -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 40
Mileage: 249070 km
Time Indication: 0
Date: 2006.03.18
Time: 01:03:44
Readiness: 0000 0100
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 G HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI USA 0010
Revision: --H01--- Serial number: 4218627
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 2959896280D7750C6F-807C
3 Faults Found:
006273 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:18
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 14.0°C
T.B. Angle: 60.0°
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:18
006241 - Throttle Position Sensor (G79)
P1861 - 000 - Error Message from ECU
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 249070 km
Time Indication: 0
Date: 2006.03.18
Time: 01:03:27
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 66C3C25E51499A7482-8032
4 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 145
Mileage: 249070 km
Time Indication: 0
Date: 2006.03.18
Time: 01:03:29
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6282
Hex Value: 0x003E
Hex Value: 0x019E
Hex Value: 0x00FF
02083 - Message for Delay Request
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 185
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:18
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0782
Hex Value: 0x002B
Hex Value: 0x0593
Hex Value: 0x00FF
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 004 - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 8
Reset counter: 185
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:55
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0782
Hex Value: 0x0014
Hex Value: 0x4394
Hex Value: 0x00FF
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 185
Mileage: 249070 km
Time Indication: 0
Date: 2006.03.15
Time: 12:00:33
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0024
Hex Value: 0x0194
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602501448705
Coding: 0000143
Shop #: WSC 49308 000 1048576
VCID: 25418552ECCF516C4B-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
1 Fault Found:
00230 - Transmission Park Selector Switch (F305)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 185
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:24
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 T HW: 4E0 035 729
Component: Interfacebox H43 3360
Revision: 00000000 Serial number: 303HR067525574
Coding: 0001003
Shop #: WSC 93078 999 100678
VCID: 33656B0A521B3FDCD5-8066
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000002013846
Subsystem 3 - Serial number: 0129.05.120000000100010483ÿ
Subsystem 4 - Serial number: 010483ÿ
No fault code found.
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000000544433
Coding: 0524326
Shop #: WSC 02145 785 00200
VCID: 1C37A0B6DF8590A4E4-8048
1 Fault Found:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:24
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0113114
Shop #: WSC 02335 785 00200
VCID: 306F6406A30D04C4A8-8064
Subsystem 1 - Part No: 4F1 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
2 Faults Found:
02746 - Bulb for Daytime Running Light; Right
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Mileage: 249068 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:00
01494 - Bulb for Parking Lamps; Left (M1)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Mileage: 249068 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:00
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 64 AIRBAG AUDI8RH29 0300
Revision: 14H29000 Serial number: 00359D0BBEN3
Coding: 0013876
VCID: 2A5B766E85D17E1466-807E
Subsystem 1 - Serial number: 6332CSME12222727T
Subsystem 2 - Serial number: 6342CSME12091561U
Subsystem 3 - Serial number: 6352QSME136E1861H
Subsystem 4 - Serial number: 6362QSME13791851D
Subsystem 5 - Serial number: 63734SME124F342D2
Subsystem 6 - Serial number: 63834SME111B3D4F8
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H03000 Serial number: 90025061840086
Coding: 0012242
VCID: 275D8F5A96C3437C79-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 931 T
Component: KOMBIINSTR. M73 H18 0110
Revision: 00300000 Serial number: 5HN399K76
Coding: 2113363
Shop #: WSC 25566 001 1048576
VCID: 23459B4AE2FBAF5C25-8076
2 Faults Found:
00438 - Fuel Supply Sensor 2 (G169)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 145
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:20
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 185
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:20
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008067268016
Coding: 6CFE73CC1B7104
Shop #: WSC 02334 785 00200
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 185
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:20
02076 - Media Player Position 1 (R118)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 145
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:07:19
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 61C9D142B867FD4C77-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 D
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381GN067504307
Shop #: WSC 02323 785 00200
VCID: 387F5C264B7DDC84E0-806C
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 148
Mileage: 247388 km
Time Indication: 0
Date: 2006.03.15
Time: 12:01:39
Freeze Frame:
Hex Value: 0x4418
Hex Value: 0x0223
Hex Value: 0x004E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0270
Revision: 00000000 Serial number: SY†
Coding: 0052971
Shop #: WSC 93078 999 85724
1 Fault Found:
00915 - Window Regulator Switch; Rear Right; Driver (E55)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 185
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:18
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01017603720000
Coding: 4618781
VCID: 2E537A7EB9391234BA-807A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
4 Faults Found:
02933 - Control Circuit for Brake Light in Trunk/Hatch Lid; Left
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Reset counter: 145
Mileage: 243286 km
Time Indication: 0
Date: 2017.12.17
Time: 16:23:16
02932 - Control Circuit for Brake Light in Trunk/Hatch Lid; Right
Freeze Frame:
Fault Priority: 3
Reset counter: 145
Mileage: 201051 km
Time Indication: 0
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Reset counter: 145
Mileage: 224000 km
Time Indication: 0
Date: 2017.08.09
Time: 14:14:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 185
Mileage: 247605 km
Time Indication: 0
Date: 2018.01.31
Time: 21:32:16
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Coding: 0000056
Shop #: WSC 45350 001 1048576
VCID: 25418552ECCF516C4B-FFFE
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000034445
Coding: 0002014
VCID: 5EB3EABE8919C2B44A-800A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 185
Mileage: 249068 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:00
Freeze Frame:
Voltage: 12.000 V
Temperature: 5.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0270
Revision: 00000000 Serial number: 'qˆ
Coding: 0052971
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0005022
Shop #: WSC 02324 785 00200
VCID: 1F4D97BACE938BBC01-804A
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 145
Mileage: 249064 km
Time Indication: 0
Date: 2006.03.18
Time: 01:03:27
Freeze Frame:
Voltage: 10.87 V
Count: 226
Freeze Frame:
Fault Priority: 4
Fault Frequency: 82
Reset counter: 185
Mileage: 245184 km
Time Indication: 0
Date: 2006.03.16
Time: 06:03:24
Freeze Frame:
Voltage: 11.18 V
Count: 241
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 40
Mileage: 249064 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:22
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394H0067673378
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 243
Reset counter: 185
Time Indication: 15
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 149
Mileage: 247388 km
Time Indication: 0
Date: 2006.03.15
Time: 16:18:02
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000090032
Shop #: WSC 94708 999 82916
Subsystem 1 - Part No: 4F0 915 105 E
Component: von VA0 1607260238
Coding: 344630393135313035452056413031363037323630323338
Shop #: WSC 00000 384 00290
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 185
Mileage: 249071 km
Time Indication: 0
Date: 2018.02.14
Time: 18:06:18
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 185
Mileage: 249070 km
Time Indication: 0
Date: 2006.03.15
Time: 18:26:07
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0052778
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000606010564
Shop #: WSC 12336 024 394758
VCID: 34676816571538E4CC-8060
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0052778
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005069345
Coding: 0010900
VCID: 285F8C669BDD4C0470-807C
End-------------------------(Elapsed Time: 02:54)--------------------------
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 07: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 36: DTCs cleared
Address 37: DTCs cleared
Address 42: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 4F: DTCs cleared
Address 52: DTCs cleared
Address 53: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 61: DTCs cleared
Address 62: DTCs cleared
Address 67: DTCs cleared
Address 72: DTCs cleared
Address 77: DTCs cleared
Old 02-20-2018, 01:47 PM
wagonpitt's Avatar
I say relay or fuse because its been happening after warm days with lots of snow melt or rainy days . So maby its getting stuck and unstuck based on moisture. Im just guessing definetly not a mechanic and not super handy when it comes to fixing. Just want some help diagnosing so i dont pay a shop to go fishing . If its something simple i can do myself i will if i cant then i can atleast point them in righr direction and not waste time/$
Im hoping i can keep this car running until spring atleast. Planning to upgrade spring or summer.
Old 03-08-2018, 05:42 PM
dardrix's Avatar
My thumb hurts from scrolling down so far. Thats alot of codes. I would check the main power distribution boxes, fuse/relay boxes for moisture, loose connections, damage to wiring harness. One bad ground wire on a harness can throw a ton of codes too. Bad batterys that overheat can cause these kinds of codes too. A battery test than a full visual inspection of the electrical system is where i would start.
Old 03-27-2018, 08:27 PM
wagonpitt's Avatar
Following cables from driver side box leads to this. Can see yellowing around bolt of red wire. Other signs of water
Drivers side box. Top
Passenger side box. Only what i think is ecu
So now that its warming up i took it apart amd had a look. Had to remove wiper arms to get to relay boxes. On passenger side box theres only what i think is ecu. Dry no signs of moisture/water marks. Drivers side box there is two 614 relay some fuses and a harness that leads to a another box a little further back and down. This bottom part has signs of water. Can someone tell me what is connected in that bottom part and what i should go after first
Old 10-05-2023, 06:20 PM
Ktm2stroker's Avatar
Default Vehicle will not turn over
Wagonpit,
I have read your post above, and I am having a very similar issue to my vehicle not turning over. The P is not always lit up, and when it is not, the vehicle will not crank. When I leave it set for several hours, I can come back and it will crank and run fine.
I have scanned it with the VCDS and getting code 00230. Transmission park selector switch, open or short to plus.
I am trying to diagnose it, and am unsure if it may be a brake switch or shift interlock solenoid by the shifter.
I was curious what fixed your vehicle?
noreserve
9
11-21-2008 08:10 PM
HGA3
Audi A3 / S3 / RS 3
12
12-27-2005 04:22 AM
daveny
12
10-28-2005 03:50 PM
iVTEC Yo(ex-B5er)
12v V6 Discussion
12
05-22-2004 07:26 AM
DMY 2.7T
01-23-2001 07:23 AM
Quick Reply: no start- vcds doesnt recognise engine control module.
