A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
O2 Sensor Errors
Old Sep 19, 2019 | 02:38 PM
Mikeythekat's Avatar
Default O2 Sensor Errors
My engine light just came on and I'm getting the following error codes and could use some help.
P0135 O2 Sensor Heater Circuit Bank 1 Sensor 1
P0133 Oxygen (Lambda) Sensor Bank-1 Sensor-1
P1196 Oxygen (Lambda) Sensor Heater Circuit B1 S1, Electrical Malfunction
P2251 O2 Sensor Negative Current Control Bank 1 Sensor 1 Circuit / Open
I assume these are all caused by the O2 sensor failing. I've tried looking up parts and find a wide range of prices and upstream or downstream. Can someone please point me in the right direction? Is this the upstream or downstream? What part number do I need and what cost should I expect?
Thank you everyone. I appreciate the help.
Chris
Old Sep 20, 2019 | 01:18 PM
jonzie77's Avatar
Sensor 1 is the upstream sensor located in the exhaust manifold. Bank 1 is on the drivers right hand side (passenger side) and I believe that would still be the case no matter what side the steering wheel is on. Although you may be able to get to the sensor without removing anything else, I found that since the airbox is so easy to remove it makes a lot of sense to just remove it and then you have all the room in the world. I bought a replacement on Fleabay for around $35 and it hasn't given me any issues since I put it in.
Old Sep 21, 2019 | 03:51 PM
Thanks for the information. It's very helpful. Do you by chance have the part number?
Old Sep 23, 2019 | 08:24 AM
jonzie77's Avatar
Here is a link to the one I bought: Oxygen Sensor Wideband Upstream For Audi A4 A5 A6 Q5 2.4L V6 2.8-3.2L 06E906265S 686514878580 .
MikeReno13
Feb 26, 2020 07:41 AM
SlvrAvnt30
Jul 3, 2007 09:10 AM
pizzer
Apr 21, 2006 11:23 AM
UseTheS4ce
Mar 25, 2005 03:45 PM
