OIL & SPARK PLUGS CHANGE
i have a 2005 audi a6
and im looking into a diy oil change,
i would like to know whats the best oil and weigh to use
on my car, i was thinking mobile1 eoro form. is this ok?
and the oil filter location.
also im replacing the spark pliugs and will like to know which ones to go with..
please help.
thanks
Mobil 1 Euro is fine...5w40.
https://www.audiworld.com/forums/sho....php?t=2839696
As for spark plugs, go with OEM, either NGK or Bosch - just order from genuineaudiparts.com and you should be set. You will also need a new crusher for the oil plug.
Any oil meeting VAG 502.00 works. The most common oil in the USA will be the Mobil (not Mobile) 1 0W40 product easily found in quarts or 5qt jugs at Walmart. Spark plugs are NGK.
