A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
P0106 code
Old Apr 23, 2017 | 10:39 AM
noffas's Avatar
Default P0106 code
I bought 2006 A6 3.2 since buying the car I have gotten a p0106 code Map sensor. I have change the sensor, spark plugs and have clean the throttle body and I am still getting the code. I notice on the on the intake hose the Resonator is missing anyone know if that would be the cause of the code?
Old Apr 23, 2017 | 04:59 PM
SchwarzS6's Avatar
The resonator is before the throttle body so it is unlikely it would have any affect on the MAP sensor. Do you have a VAG-COM scan? It may tell you more information such as if there is an open or shorted connection (indicative of a bad cable/MAP sensor) or implausible signal which could indicate a bad vacuum leak. Just because you have a new MAP sensor does not mean that it is not faulty, particularly if it is not OEM. I have had bad luck with recent aftermarket parts recently, some of them are real junk.
The resonator should not be removed, it is there for a good reason. If it is missing, make sure the port where it was connection is plugged, otherwise you will suck dirty air into your engine.
noffas
Apr 23, 2017 09:15 AM
noffas
Apr 23, 2017 08:37 AM
chrisbob
28
Feb 23, 2013 05:48 AM
ledzepp2994
Jan 9, 2012 01:34 PM
TaciTrequiem
Jan 29, 2005 01:35 PM
