A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
right rear window switch
Old Oct 9, 2016 | 08:25 PM
raaizin's Avatar
Default right rear window switch
The right rear window switch has stopped working. It works in the down position sometimes. From the drivers door it works fine. I guess it is just the switch. A little liquid was dropped on the switch. I see the armrest on ebay with switch. Or should I just get the switch? How difficult is this to replace?
Ray
Old Oct 10, 2016 | 11:28 AM
raj99's Avatar
Tech Guru
Tech Guru
Ray
Ray,
I'd just get the switch and all you need to do is remove the interior door panel...it's actually not that hard:
https://www.audiworld.com/forums/a6-...tures-2906617/
Old Oct 10, 2016 | 11:39 AM
beep-beep's Avatar
25 Year Member
Ray
I think the part number is 4F0959855A5PR
you can find one on ebay for $7: Front Right Rear Window Switch Button for Audi A6 S6 C6 RS6 Allroad A3 S3 Q7 | eBay
you tube has a few videos how to take off the rear door panel. You would need some driver bits and a 2" putty knife or another flat object to pry off the clips.
the operation is very easy if you follow instructions.
Old Oct 10, 2016 | 01:25 PM
raaizin's Avatar
I put a few drops of water on the switch(from above did not remove door panel) and blew it out with compressed air. I figured since the switch was shot I had nothing to lose. I did this a few times and switch is working. At first it worked intermittently but now it works good. If it becomes a problem I will remove door panel and replace the switch. I am not sure how switch works but it appears something in drink fouled the contact points.
Trango
Audi allroad
15
Jan 26, 2019 03:01 PM
Maini
Jul 14, 2008 10:53 AM
5000Q86
Jun 29, 2008 09:09 PM
s4sd2007
Jan 7, 2008 07:33 AM
ssmokn
Audi allroad
Aug 23, 2005 03:23 PM
