A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Solar Roof Not Working??
Old Sep 3, 2010 | 02:17 AM
Eric5412's Avatar
Default Solar Roof Not Working??
I think my solar roof stopped working. I no longer hear the blower motor running nor feel air coming from the vents when I turn off the ignition. Any ideas how to test? Or how to know if its even running or not. It is set to on in the climate control setup menu.I've read somewhere that the A8's have a relay or module, what about my A6?
Old Sep 3, 2010 | 03:05 AM
KevinGary's Avatar
Community Builder
I can feel the air coming our of the center vents when mine is running. If you can't feel the air, or hear the fans turning, it must not be working. When did you first notice that it was not working?
Old Sep 3, 2010 | 10:39 AM
Eric5412's Avatar
I noticed just a couple of days ago.
Old Sep 4, 2010 | 06:38 PM
BlueCat_A6_allroad's Avatar
After reading this thread I paid attention to my car today and definitely noticed the noise of the fans and airflow from the center vents.
I cannot think of a test you can do other than park in a sunny location on a hot day. Might be a free check at the dealer if your car is under warranty.
Old Sep 4, 2010 | 07:32 PM
Eric5412's Avatar
Yeah, I used to hear and feel it too. I parked out in direct sunlight today, and NOTHING. Could it maybe be dirty/clogged pollen filters? Maybe my blower motor is going?? I was just wondering if there was an thing easy I could do/check before I bring it to the dealer. My car is no longer under warranty.
Old Sep 5, 2010 | 04:24 PM
Arnold K.'s Avatar
How do you know if you have this feature? I had no idea this was even available. As far as I know, my A6 4.2 is fully loaded, except S-Line.
Old Sep 5, 2010 | 06:15 PM
parkal's Avatar
Where is your location? Solar roofing is very essential and I think the best thing to do is to go to the nearest audi cars so they can do the correct test.
Old Sep 5, 2010 | 07:22 PM
monkeytronic's Avatar
If the C6 solar sunroof is anything like the solar sunroof the '02 C5 A6 4.2 I drive is equipped with, just look at the top exposed surface of the sunroof. It's a huge PV solar panel--rated to produce 33.6W under direct sunlight in the case of a C5. You can't miss it.
Inside the car you should find that there's no sliding sunshade and instead there's an interior trim panel permanently attached to the bottom half of the sunroof. That's because there's no translucent glass to look through when the sunroof is closed as is the case with the much more common moonroof.
When the sun's out, the solar sunroof should only operate if it's fully closed or tilted up in its vent position. If it's slid backwards in any position it won't work.
Old Sep 6, 2010 | 02:37 AM
KevinGary's Avatar
Community Builder
If your sunroof has a retratcable headliner so that you can see the glass from inside the car you do not have the solar sunroof. Based on your prior post regarding falling sunroof springs I am betting that you do not have the solar sunroof. Back in 2005 there were so many stand alone options that there are very few fully optioned cars. I sent an e-amil to Audi several years ago and while I forget the exact number I think there are less than 20 fully optioned 2005 A6s in the US. From what I recall the rare options in the 05 were the solar sunroof, Tire Pressure Monitoring system and the optional supplemental air bag system.
Old Sep 6, 2010 | 01:44 PM
Eric5412's Avatar
Arnold: This is what the solar roof looks like.
Today it's a bright sunny day so I just checked whether my solar roof is operating. As I enter the car it is NOT running, I turn the ignition to the on position, go into climate control's setup, scroll down to solar operation (which is set to on),I switch it to off then exit setup, then I go back in and turn it on, exit setup, switch ignition off and NOW it's RUNNING. It did the same thing yesterday. Any idea whats going on here?
