A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Problems after pad change in 07 A6 3.2
Old 06-20-2011, 12:04 PM
bud4ya's Avatar
Default Problems after pad change in 07 A6 3.2
Just changed the pads on my A6 and now when I turn left it makes like a humming noise and you can feel vibration. Any thoughts?
Old 06-20-2011, 02:15 PM
am_ver's Avatar
hmm.. were the clips holding the pads tight? could it be possible that the pad has come off from the caliper?
Old 06-20-2011, 03:28 PM
bud4ya's Avatar
I just took the car out and it brakes fine. I made one really sharp left and I could feel some vibration in the gas peadel. Only could make it happen once. Wife was the one saying it was doing it all the time. Like I said I tried it and it made a vibration in the gas pedal once
bud4ya's Avatar
Clips look to be in place
Old 06-21-2011, 04:04 AM
bud4ya's Avatar
I drove it again this morning and every now and then I still get the vibration in the gas pedal. This time it was while I was going straight and not in the corner. Like I mentioned it does not happen all the time just here and there
Old 06-21-2011, 02:06 PM
gk1
gk1's Avatar
Default Did you only change the pads?
Did you also change the rotors or at least resurface them?
Otherwise it is likely it is the pads vibrating from the ridge on the rotor left behind from the old pads. The A6 brakes may be more prone to this than others. My stock brakes had a similar problem after about 20k miles. Only going slow and turning hard...i.e. parking. The ridge around the rotor was so high the pads would catch on it and make a noise...going straight the pads managed to ride in the ridge and were fine.
Old 06-21-2011, 03:19 PM
bud4ya's Avatar
I think that is issue. Hopefully pads wear down and it stops. There is a ridge
Old Salt 64
08-06-2011 06:30 PM
biffed
01-26-2008 09:29 AM
boxster02
08-21-2006 06:45 AM
nats
11
08-30-2002 06:34 AM
leonardl
12
11-13-2000 06:39 AM
Quick Reply: Problems after pad change in 07 A6 3.2
