A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
oil leak in vacuum pump in 2005 audi a6
Old 02-20-2015, 10:54 AM
bballfreak's Avatar
Default oil leak in vacuum pump in 2005 audi a6
i have the gasket O-ring as well as the odd shape gasket
for the vacuum pump.
Can someone post directions on how to do this
with torque specs etc.
This is for a 2005 audi a6 3.2L quattro BKH engine
Old 02-20-2015, 02:07 PM
milan_o's Avatar
The o-ring and gasket I ordered should be here today. Two pieces of info
https://www.drive2.ru/l/1054271/
And then the actual instructions on how to remove / replace the vacuum pump.
Vacuum Pump, 3.2L Gasoline
The vacuum pump is attach to the to the left side of the engine at the front
Removing
– Open the clamp on the vacuum hose using suitable pliers.
Note:
Depending on the model, the vacuum hose to attached to the vacuum pump by screws.
– Remove the vacuum hose.
Caution
Be careful not to damage the vacuum hose. Replace the vacuum hose if damaged.
– Remove all the screws on the vacuum pump sealing flange.
– Remove the vacuum pump from the vehicle.
Installing
Installation is done in reverse order, but observe the following:
Note:
Replace O-rings.
– Position vacuum pump drive so that it engages in groove on camshaft arrows when vacuum pump is installed.
– Install all the screws into the vacuum pump sealing flange and install the pump, and then tighten to 9 Nm.
Note:
Depending on the model, the vacuum hose must be attached to the vacuum pump, to 5 Nm.
– Slide the vacuum hose and the new hose clamp onto the vacuum pump connection.
Caution
– Close the hose clamp with pliers.
Old 03-07-2015, 07:38 PM
ILLusive's Avatar
ordered these parts since I'm seeing the same type of leak. Thanks Michael!
Old 05-09-2015, 08:47 AM
bballfreak's Avatar
I also ordered the parts, the weird I found in my 2005 Audi A6, 3.2L Quattro BKH, there is only o-ring. There was no 3-leg gasket. But this gasket lines up exactly and seems to be ab exact fit. I do remember back in 2009 the Audi dealer had replaced this gasket.
So, am I suppose to put the gasket and the o-ring when I put it back together?
Any gurus out there?
Thks
Barry
Old 05-09-2015, 08:49 AM
bballfreak's Avatar
Also, the Bentley manual shows only replacement of o-ring, for this year 2005 Audi A6, 3.2L quattro BKH engine
Old 05-09-2015, 09:15 AM
milan_o's Avatar
I had both parts on mine.
FYI you do NOT need to use a lot of force to get the pump back in. If it doesn't want to go back in, you don't have the pump lined up properly.
Old 05-10-2015, 05:04 AM
bballfreak's Avatar
Ok, thks, Milan.
I did install both the gasket and o-ring.
and was quite easy to do this.
Looks like the leak has stopped.
Old 04-16-2016, 05:22 AM
conitssap's Avatar
Thks
Barry
Do you happen to have the exact part number - the dealer is not sure themselves
Thanks
Old 04-16-2016, 05:35 AM
conitssap's Avatar
Thanks
ok found the part #'s myself
06D145117 - o ring
06E145215A - Gasket
Old 04-16-2016, 05:37 AM
bballfreak's Avatar
I replaced both, but after a while it was still leaking.
The pump had an internal leak, so I bought a new pump
which only had o-ring and no more oil leaks
Quick Reply: oil leak in vacuum pump in 2005 audi a6
