2010 A7 headlight issue
Old Feb 23, 2020 | 07:05 AM
lullabY's Avatar
Default 2010 A7 headlight issue
I've seen threads with a similar error before but haven't found a working fix for it.
I took my A7 in for maintenance at an Audi certified local workshop and since my LED number plate lights were blinking, I told them to also replace those. They told me that the originals shouldn't be LED and replaced them with regular non-LED ones.
I took the car home and didn't notice anything strange. However, next day (or possibly right after receiving it from maintenance, but I just didn't notice) the car started showing error "Vehicle lights malfunction". I took it back, they connected it to a computer and told me that the lights are giving some errors. Unfortunately, they didn't tell me what the exact errors were. They said I should replace the headlights (~2300€/piece). Since I still hope there's another way to fix this, I'm looking for advice on how to resolve this.
So basically I have 2 issues as far as I know (both seem to do with the passenger side headlight). The car is left-hand drive, so the headlight in question is on the left in the images below.
1) Daytime lights are not being lit properly:
  • This is how it looks when the ignition is OFF:
  • This is how it looks when the ignition is ON:
As you can see, an extra light is on when the car is running.
2) The second issue is with the passenger side curve light. When turning left, the curve light is working fine, but when turning right, the right-hand side is not being lit.
"Vehicle lights malfunction" error is being shown every time I start the car. All other lights seem to be working just fine. When turning the light **** to main headlights, they all light up just fine.
What I've tried:
  • Checked the corresponding fuses ("Vehicle electrical system control module 1&2" and also "Headlight range adjustment/adaptive lighting system") and they were fine
  • Put back the LED number plate lights and tried turning the car on, but the same error occurred, so I switched them back
  • Just before writing this post, I put back the LED number plate lights again and decided to leave them on for some time to see if it fixes the issue
  • Put the headlight **** to different positions (even off) and then turn the car on, but the error is being shown every time
  • Bought an OBD2 cable and used "OBD Auto Doctor" to scan, but I only scanned the engine and transmission, so no help (I also didn't find any info on if I could see these kinds of errors if I bought the paid version and use that instead of the trial version)
Any ideas on what I should do?
Barry Petty
Q7 MK 1 Discussion
Jul 14, 2018 11:22 AM
dvlgrrl6
VAG-COM Discussion
Jul 23, 2014 06:50 PM
JGood
Jun 16, 2014 04:49 PM
B7Quattro Pete
A4 (B7 Platform) Discussion
Jun 18, 2008 12:12 PM
KevinM
10
Feb 16, 2004 05:09 PM
