4 spoke to 3 spoke
Old Nov 4, 2016 | 05:53 AM
bamberjim's Avatar
Default 4 spoke to 3 spoke
Hi all,
Just got myself a 2014 3 spoke steering wheel with paddles (S-Line) to replace my 2011 4 Spoke with paddles.. the new wheel has all the same buttons as the current one.. should this be a straight swap over without going into the VCDS thingy
Thanks Jim
Old Nov 4, 2016 | 08:22 AM
tenspeed's Avatar
Sounds like a direct swap. Before pulling the old wheel off the spline, look for index marks so your new wheel is positioned correctly.
Old Nov 5, 2016 | 05:12 AM
Iceman22's Avatar
From what I've seen on same topics, you will need a new airbag - three spoke and four spoke airbags are different. If the buttons are exactly the same, then you will not need to code it.
Old Nov 6, 2016 | 01:15 PM
bamberjim's Avatar
Thanks all for the info, the wheel comes with the airbag so all good on that front..
Cheers Jim
phillys4951
Oct 30, 2005 08:08 PM
Davidteri
Feb 16, 2005 07:06 PM
MILLARACING
Feb 8, 2004 01:53 PM
21212
16
Sep 12, 2003 07:04 PM
