Audi A7 Headlight problem
Old Oct 6, 2022 | 11:52 AM
Eetvark's Avatar
Default Audi A7 Headlight problem
The car is an Audi A7 2011. The right headlight bulb broke and I took out the old bulb which had exploded for some reason. I replaced the bulb with a similar one and tested whether the lights work. Everything else in the lights works except when I put the high beams on and back to the low beams, the headlight directional motor on this side directs the light down to the right and I get an error codes:
CENTRAL ELECTRICS
Headlamp range control module
Fault code: 01771
Status: Static
HEADLIGHT REGULATION
Right Variable headlamp posting motor
Fault code: C109707
Status: Static
Sensor for right variable headlamp positing motor
Fault code: C109902
Status: Static
ON BOARD CAMERA
Function limitation due to received malfunction value
Fault code: U111300
Status: Static
I have to turn off the car and start it again, then it directs the light again to the correct position. Could someone help what could be wrong with the car?
Radstar
A6 (C7 Platform) Discussion
Oct 9, 2024 05:40 PM
Jmartin827
Jan 17, 2019 06:36 AM
jlbell
Feb 1, 2017 08:18 PM
CobraCommander
Jan 5, 2015 04:23 AM
Kenny
14
Jul 31, 2008 10:23 PM
