Audi Led Light Blinker Issue
Old Feb 27, 2023 | 11:16 AM
EricSinyakov's Avatar
Default Audi Led Light Blinker Issue
Hello, I have an audi A7 it comes with led headlights and my issue is that the turn signal blinks but not all lights light up. Drl works perfectly as well as low and high beams. I get a code 03848 and computer says "Right front turn signal- Electrical error in circuit". Any info and help appreciated. Have no idea where to look or if this is fixable.
Old Feb 27, 2023 | 11:44 AM
fkaufman's Avatar
It is a defect inside the light assembly. The official Audi response is to replace the unit.
However, this kind of defect is fixable. Unfortunately it involves removal of the light assembly, opening it and finding the defective component on the LED driver circuit board. All you need is a Voltmeter. It may be a bad transistor, a bad IC or a broken PC board trace.
Old Feb 27, 2023 | 12:00 PM
Originally Posted by fkaufman
It is a defect inside the light assembly. The official Audi response is to replace the unit. However, this kind of defect is fixable. Unfortunately it involves removal of the light assembly, opening it and finding the defective component on the LED driver circuit board. All you need is a Voltmeter. It may be a bad transistor, a bad IC or a broken PC board trace.
Does it involve taking apart from the back or the lens?
Old Feb 28, 2023 | 05:20 AM
fkaufman's Avatar
You have to remove the whole light assemble, then take it apart.
Hamza
A4 (B9 Platform) Discussion
Oct 2, 2022 11:57 AM
Kamool
Q5/SQ5 MKII Discussion
Oct 4, 2021 06:50 AM
obfuscate
A7
Mar 19, 2019 06:17 PM
RS5Z
Mar 18, 2013 09:49 AM
paliracer
Feb 21, 2005 11:45 AM
