Back up camera not working
Old Apr 12, 2020 | 03:20 PM
dx3's Avatar
dx3
Default Back up camera not working
I have a 2012 Audi A7. Whenever I go into reverse the MMI screen stays on navigation and does not change to the back up camera. I also noticed when I go into reverse I get a long beep. I found one thread where that said there was an error when it made the beep. I have been reading every post I can find, but most of them relate to the Q or A4. I dislike my local dealer, and the local shop that works on Audi said he's never dealt with this issue before. I read one thread where you could go through the Car settings to make sure rear camera was selected. I played with my controls and did not locate an option for this.
I've found multiple threads about the back up camera flickering, but not much related to the A7 and it now working at all. When I bought the car I repaired the 2 wires on the back that always fail to get power back to the screen, but I didn't remove any other wires back there. I have a scanner that I can use, but I don't know if it's sufficiently in depth to help me.
Any ideas or threads I may have missed? I have read about bad camera, bad control module, bad harness, but none were on the A7. Thanks,
Jonny
Old Apr 13, 2020 | 09:11 AM
dx3's Avatar
dx3
Well, I guess I will keep updating this until someone has an epiphany.
I called Audi and they verified my car came with the KA2 option (rear camera.) So I checked in the trunk and the entire bracket for the Camera control module is not there, nor is the harness connecting to it. So why would someone remove this? It makes no sense.
Further research showed in 2012 due to the Tsunami a lot of Audi's were released for sale without the camera equipment installed, on the basis that they didn't want to hold up shipments just for this. I believe the theory was that when these parts came in, people would bring the car in to the dealership and have these few remaining parts installed. So possibly, this car that was supposed to come with a back up camera never actually had all of the equipment installed, and the first owner never went back to get it installed. This is what I have read, I am not saying this is true as it's from the
I have put a call in with Audi and they are telling me the car did come with it and it was installed in 11/2012. So basically I am no further along.
Old Apr 13, 2020 | 09:41 AM
fkaufman's Avatar
Your information is absolutely correct. I had a 2012 A7 that was delivered to me in July 2011 without the rear view camera installed. Sometime in October 2011 I got a letter that the parts were available and I was to make an appointment to bring the car in. The installation and calibration was to take 3 hours.
I did make the appointment, the parts were installed on November 28th, 2011 and the rear view camera system functioned flawlessly for as long as I owned the car.
I am certain that the cable harness and bracket was installed at the factory and they only had to add the camera unit.
The tsunami hit in March 2011 and the resulting parts shortage affected cars built from April to October. This would suggest that since the parts became available in October 2011, if your car was built in November 2011 it did have the option installed at the factory.
Old Apr 13, 2020 | 09:58 AM
dx3's Avatar
dx3
I appreciate your response sir, thank you. It seems I have the camera unit, just not the bracket/harness/control module. By chance do you know which side of the vehicle it is supposed to be on? I spoke with Audi who tole me passenger side rear somewhat behind the taillight. But when I look it seems on my car it's driver's rear side...? Any ideas?
Old Apr 13, 2020 | 11:30 AM
fkaufman's Avatar
Unfortunately I don't have that car any longer (traded it in 2015 for an A7 TDI) so can't look at it.
However, the service manager or the lead technician at an authorized Audi service center could look that up for you and print out the appropriate pages, if you ask (nicely).
Old Apr 26, 2020 | 03:48 PM
James Zeinner's Avatar
I had the same issue with my A7. The rear sonar sensors share a common ground. Where the ground wires are crimped together to a single wire to go to the harness connector was corroded and broken. Repaired the splice and the rear sonar and back up camera works now. Im unsure why the camera is tied into the sonar but if they don't work the camera wont turn on. Pull the bumper and check continuity from the connector to each wire.
onionhead
Jul 27, 2024 05:36 AM
yenlee711
Aug 24, 2016 04:38 AM
NickW_UK
May 7, 2014 08:14 AM
Mattmalka
Q7 MK 1 Discussion
15
Nov 20, 2013 08:17 PM
UW RL
Q7 MK 1 Discussion
Feb 19, 2008 03:07 PM
