Brake Pad Warning Light
Everything I've read suggests not to replace the rotors (scam by mechanics (usually)).
Does anyone have experience going to an independent shop versus the dealer for this service? The car has been serviced exclusively at the dealer.
Thanks
The front rotors are 34 mm with a 31.5 mm minimum. Rear rotors are 22 mm with a 20 mm minimum thickness.
Thanks
I called my trusted local Audi dealer. The wanted around $1,100 to replace all rotors and pads.
Took it to a local recommended shop that works with Audis. Akebono pads on all 4 (rotors didn't need replacing) and labor was $360. Went with them and no issues.
Wondering if anyone could help me figure out my issue as cheaply as possible.
My Audi Q5 2010 has 68000 miles on the clock and full and regular service history with Audi Approved service centres.
At 54000 Miles I had the rear break pads and discs replaced at Sydenham.
At 67000 (only 1000 miles ago) I had the front pads and disks replaced at Wimbledon, following a full service.
This evening, driving home, the amber warning light for my brakes appeared on the dashboard.
Reading through this thread, I am not sure how the vehicle requires new front or rear pads after such a small interval. If there was an issue with one of the brake components, such as a corrosion, would this not have been picked up in the engineers report or addressed whilst replacing the brake pads and discs just a few weeks ago?
Any help greatly appreciated as what was a bargain pick up at the time is not bleeding my bank account dry!
Many thanks,sid
Thanks again,
Sid
