Engine Air Filter
Old Apr 15, 2016 | 03:48 AM
masonL's Avatar
Default Engine Air Filter
Can someone tell me where the Engine Air Filter is located on my 2012 A7?
Thanks.
Old Apr 15, 2016 | 05:59 AM
tenspeed's Avatar
Engine compartment - passenger side - front.
Old Apr 15, 2016 | 06:30 AM
masonL's Avatar
Thanks - that's where I looked but couldn't find it - isn't it about the size and shape of a coffee can and it's within the hose piping?
Old Apr 15, 2016 | 10:59 AM
tenspeed's Avatar
The filter is inside the air box. There's a conduit at the front feeding outside air and a plastic intake pipe between the airbox and the throttle body located aft of the supercharger.
To put your hands on the filter, loosen the two hose clamps on the intake tube (7 mm IIRC). Remove the tube and move it rearward out of the way. You don't have to remove the hoses mounted on the tube. There is a round plate at the rear of the box with one catch holding it in place. Press in on the catch and rotate the plate. If the plate still seems attached, pry up on the edge with a putty or butter knife. The plate pops off and the filter is exposed.
Grab the shop vac - there's usually leaves and such in the bottom of the box. The filter has a white pre-filter. You can carefully work that off and bang it against the trash can to dislodge the dirt in the media.
Old Apr 17, 2016 | 03:54 PM
masonL's Avatar
Thanks VERY much - found it and mission accomplished!
bjterp00
S7
Jul 6, 2020 11:01 AM
longtooth
A6 (C7 Platform) Discussion
Jul 11, 2013 03:12 PM
DrChaos
Audi A3 / S3 / RS 3
Jun 19, 2009 02:49 PM
precisionloans
Apr 14, 2006 01:40 PM
dunkmstr
Sep 1, 2004 09:40 AM
