Glass Break Sensor Code: 01403
Old May 24, 2025 | 01:31 PM
A6 4.2 Vier's Avatar
Default Glass Break Sensor Code: 01403
I was getting the glass break sensor code on my 2018 A7 so I removed the rear hatch interior trim expecting to find an electrical connector not connected.
Instead I found one of the solder connections not making contact on the passenger side. I couldn't tell by looking at it but the tab on the left was separated from the contact on the glass.
I pryed the connections completely off which I added some solder with a solder gun.
Then I held the connector back in place and hit the solder tabs with more heat from my solder gun to melt the solder creating a solid electrical connection.
There are two solder tabs (about 3/4" apart) on the passenger side and one solder tab on the drivers side.
If you measure between the 3 solder tabs you should get contunuity.
I recently purchased the A7 used which the previous owner had window tint installed which may have caused the issue.
All working like new again.
Scotty1970
Q5/SQ5 MKI (8R) Discussion
Aug 6, 2023 06:57 PM
BMWBig6
A4 (B8 Platform) Discussion
Jun 15, 2015 06:13 PM
toothandnail
Oct 21, 2010 05:53 AM
MaxHedrm
Dec 26, 2006 04:23 PM
Biscuit141
Audi 100 / A6 (C4 Platform)
Apr 14, 2004 10:13 PM
