headlamps!!!
Old Jan 2, 2013 | 04:49 PM
A7assan's Avatar
Default headlamps!!!
Hi every one... igot audi a7 2012 ... am dont know if it is issue or not my headlamps doesn't work .. it is work only if i go to (menu then car option then exterior lights then there is option... light for driving on left .. when this option is on my headlamps doesn't work when it is off the headlamps start working .... but with strange thing .. i found that the light range for the both lights in right position not in the middel always am notice that when come in any bump on the road and the car go up and down ifound that the lights not in middel postion ... is it problem ????? Sorry to my bad english it is not my languge
Old Jan 2, 2013 | 10:35 PM
A7assan's Avatar
Any answer please ......
Old Jan 2, 2013 | 11:46 PM
DeerHunter's Avatar
Where are you located? It seems you're describing the European-specifaction function that allows you to drive on the opposite side of the road without dazzling oncoming drivers.
So, which model of car do you have and which side of the road do you drive on? It sounds like you have a car designed for driving on the left-hand side of the road. In that case, then the "drive on right" option in MMI will reduce the light output because the cut-off will now be completely straight (no light band to light up road signs).
Or, you have an issue with the lights. Since you have a 2012 model, surely it's under warranty and you can take it in to a dealer for inspection? If they're far away, at least give them a call to ask their advice.
Good luck.
Old Jan 3, 2013 | 03:53 AM
A7assan's Avatar
Thank you dear ... my car is gcc gulf spec we are driving in right
Old Jan 3, 2013 | 07:32 AM
DeerHunter's Avatar
Okay then. First thing is to leave the light option in the menu set for the right. The problem at this point is probably that the lights are not aimed properly. Their might be a procedure to set this with a screwdriver, but you'd be guessing as to the correct level. I recommend that you take it to the dealer or a good mechanic for adjustment.
Jake Myers
Audi A5 / S5 / RS5 (B9)
Apr 12, 2018 05:48 PM
fondoo
Jul 28, 2017 06:27 PM
Sithquest
Jun 19, 2008 11:43 AM
R2.7TA6
Rocky Mountain Discussion
Jul 7, 2005 09:58 PM
SilveRazeR
May 19, 2005 07:50 PM
