Help with fault code POC2A00
Old Aug 6, 2025 | 06:12 AM
JK69's Avatar
Default Help with fault code POC2A00
Hi All
I've owned a couple of A7's for a few years now, and recently got an'18 plate A7 55 tfsi. (65k mls) I have received this code (amongst others - less worrying..).
Message says:
Transmission:
P0C2A00 - Auxiliary Transmission Fluid Pump: Motor Stalled
Freeze frame
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Odometer reading: 66057.3 miles
Transmission output speed: 0 RPM
Engine torque: -4 Nm
Engine rpm: 2444 RPM
Driving position: P
ATF temperature: 86 °F
Voltage terminal 30: 14.1 V
Selected gear: 1
Ctrl. mod., operating condition: Regular operation
Auxiliary pump for transmission, requesting function: Emergency run since calibration was not performed
Auxiliary hydraulic pump for transmission oil, current: 16 A
Oil pressure reservoir, pressure: 416.3 PSI
Pressure of clutch 1, actual value: 0 PSI
Pressure of clutch 2, actual value: 0 PSI
Clutch status: Neutral
I can clear the message when the car is warmed up and it seems to go away and car seems to work fine. When first just switched on though, it wont even let me select a gear.
Has anyone experienced anything similar at all?
Thanks for any input.
Cheers
JK
central50
A4 (B9 Platform) Discussion
19
Feb 12, 2026 08:32 AM
Tanertimur
Q5/SQ5 MKII Discussion
Mar 26, 2025 12:59 PM
darthbader
Q5/SQ5 MKI (8R) Discussion
Mar 2, 2024 11:48 AM
UK PL
Audi A5 / S5 / RS 5
Dec 4, 2023 02:42 AM
audi83
Aug 29, 2022 09:58 AM
