removing door panels
Sully
On down bellow, one in the interior handle and one behind the interior decor trim (only clips, start at the front).
There are clips on each side, and on the bottom.
There is an overhanging lip on top, so when the screws and clips are done, just lift the panel.
I recommend 2 persons to do this job, if your going to takenthe panel off the car. As you might need some help holding the panel when you undo the electonics.
