Seatbelt pretensioner error (Audi pre sense not available)
Last time when I started my car this error appears. I have checked the error with VCDS 18.9.0.2, so I'm thinking that this error might be caused by the seatbelt pretensioner, what you guys say and what I must change to fix the problem?
Car: Audi A7 3.0 TDI 245hp 2011 S-tronic CDUC engine
Address 90: Pretensioner. DF (J855) Label: 4H0-980-94x-RGS.clb
VAG number SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
Coding: 0066E608031F037E070308014240C2010000
Workshop: WSC 02391 785 00200
ASAM package: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70EF66C1ABA314CA25-8024
1 code found:
12588800 - Command mode
B2000 98 [137] - defective
[New property! Extended data UDS codes are only supported by generic. nine of interfaces]
MIL on - Confirmed - Tested from memory wipe
code circumstances:
Fault status: 00000001
Defect priority: 1
Defect frequency: 1
mileage: 204205 km
Date: 2023.06.08
time: 10:31:03
Did either of you get the problem fixed? I m having the same warning on my instrument cluster. Is it just the pretensioner to be replaced? My pretensioner motor seems to be working even though it shows faulty seat belt module.
