Steering wheel scroll wheel problem
I'm having the same problem, literally every button works - including when I press the scroll wheels - but neither works when I scroll up or down. I'm using OBDEleven live data to test. Both worked fine then stopped working at the same time. I tried replacing the steering column switch/clock spring assembly but that didn't fix it.
Not an issue since I mainly use the steering wheel volume.
