Super weird no-crank no start issue
Old Apr 25, 2023 | 10:05 AM
taga8's Avatar
Default Super weird no-crank no start issue
So thought I would let everyone else know what I found, in case you run into it. Have a neighbor with a 2013 A7, could not get it to turn on at all (but the door locks worked). He had it towed to a mechanic, mechanic took 2 days going through it with no luck. I went to the mechanic's lot, plugged in the vag-com, car would not communicate at all to ECU/TCU and wouldn't auto-scan. I did a scan of the can-gateway directly, which was communicating, showing an issue with a break in the MOST ring. So I cleared the codes on the can gateway, disconnected the battery for 10 minutes, reconnected the battery. And the car was alive!!! Rescanned all the modules, cleared all the comm errors throughout the modules and the car has been running like a champ ever sense.
Old Mar 15, 2025 | 03:45 PM
Hangtenboy's Avatar
Did you connect to gateway directly through VCDS? I’m having a similar issue and have legit cable and software as well. Car seems to be behaving the exact same as your buddy
JohnnyT13
Jun 21, 2024 04:05 PM
Adisz
Q7 MK 1 Discussion
21
Jun 3, 2020 11:42 AM
ruf63
14
May 13, 2017 04:49 PM
gorham7
Mar 10, 2017 01:50 PM
wfroehlich
11
Dec 8, 2016 04:37 PM
