Vibration on driving
Old Nov 12, 2019 | 01:03 PM
sh1nexsus2012@gmail.com's Avatar
Default Vibration on driving
Hello Guys
Last time I have faced a problem with my A7 2015 after I changed the 4 tires which is that When I start driving and speeding up reach 100km/h the car start vibrating And I can feel that vibration in the front passenger seat especially
plz tell me what is the problem could be??
Old Nov 12, 2019 | 04:36 PM
Baloo588's Avatar
Likely bad balancig job or poor set of tires. What tires did you get and did you do Hunter Road Force balancing? Its a must to get that glass smooth factory like ride when replacing tires on these cars. I never ever do regular balancing with my tires or rims. I also stick with higher quality brands like Michelins, Bridgestone etc which have better tire quality that are more round and tighter tolerance to avoid out of roud tires that can cause slightest vibraitons on these cars with low profile tires and big rims.
https://www.hunter.com/wheel-balancers/road-force-elite
Locator: https://www.hunter.com/gsp9700
My A7 is glass smooth when I do this type of balancing or else I will get vibraiton in the seat or steering wheel at highway speed which is extremely annoying. I am running 275/35R20 Michelin Pilot Sport 4S on my 20 inch rims for summer and a separate winter set with Blizzak WS90 size 245/45R19 on 19 inch rims. No issues with both.
Old Nov 14, 2019 | 09:58 AM
davepjr71's Avatar
I have the same issue and it started after I hit a large pothole. The dealership said they couldn't find anything wrong. I've had the front end checked and run Michelin tires. I could actually hear a sound associated with this that has started to get a little worse lately. I'm surprised to see that some Mr. Tires have the Roadforce balance elite. Do you have to specifically ask for this to be done or do they do it to every car?
Old Nov 14, 2019 | 03:31 PM
Baloo588's Avatar
o
Hi you must specifically tell them to do it , it's a premium over regular balancing and cost 150 to 200 dollars for all 4 wheels and tires and takes a little longer to do then regular balancing. You also need to make sure then match the tire and wheel and get road force in single digits and not greater than 10 lbs or it will cause vibration. Also many techs at these chain tire stores aren't very skilled at using these elite machine and it's baffling but you need to ask for the senior tech or most experienced one. I go to an independent Euro shop and the tech there is suberb he knows the ins and outs of road force balancing. Dealerships aren't the best for road force in my experience.
Old Nov 28, 2019 | 06:38 PM
tomhorn's Avatar
Could also be a bent wheel. Had that issue with my A5.
cipher99
Audi A5 / S5 / RS 5
Jun 2, 2019 02:14 AM
Gbob
TT (Mk3) Discussion
10
Nov 14, 2017 07:36 AM
bfairban001
May 1, 2017 03:33 PM
Trent
Apr 9, 2004 11:55 AM
HDClown
Florida Discussion
Sep 30, 2002 11:49 AM
