Tailgate 12v supply
I'm thinking of maybe taking a positive supply from the rear-view camera, lock mechanism, or whatever else is under there! Ideally, it'll be a switched supply (ignition on), but it doesn't have to be.
Anyone got any clues?
[trunk lid open]
I realize this does not answer your need for the switched power source, but is to show that it can be done.
One issue we discovered was if the camera was installed on the rear glass (as shown in the picture), it really interfered with AM reception. Once we discovered this, I moved the camera onto the trim piece. All good. Just a heads-up if you encounter a similar issue.
Situation:
2019 A7, USA model
Have the Smart car / google earth package, but not the WiFi Hotspot option
Apple CarPlay works over wifi, but data over LTE, now
Can you WiFi attach to the camera, and use Apple Car Play WiFi?
Thank You
Both cameras record to an internal mini-SD card in the front camera. If you have an on board hotspot (I do not as I allowed the spendy Audi Connect option to expire), the live video feed can be pushed to a smartphone or a computer (thus I haven't). The rear camera takes its power from and sends its recordings to the front camera so it does involve running a provided cable between front and rear. To view the clips, either download them from the SD card via a reader or use the front camera's WiFi-out to a smartphone's installed Blackvue app or to the computer.
Again, I wasn't present for the install, but the shop only charged out one hour of labor for the entire job, really super clean n tidy even for an obsessive such as myself.
Both cameras record to an internal mini-SD card in the front camera. If you have an on board hotspot (I do not as I allowed the spendy Audi Connect option to expire), the live video clips can be pushed to a smartphone or a computer (thus I haven't). The rear camera takes its power from and sends its recordings to the front camera so it does involve running a provided cable between front and rear. To view the clips, either download them from the SD card via a reader or use the front camera's WiFi-out to a smartphone's installed Blackvue app or to the computer.
